I crossed the exhaust VANOS valve connector wires.
Old Feb 23, 2021 | 08:29 PM
Don Brown's Avatar
Don Brown
I think I may have screwed the pooch when I was doing some maintenance on my wife's Mini. The wire connector on the exhaust Vanos valve had become quite deteriorated on my wife's 2008 Mini Cooper r56 n12 hatch base so I ordered a new connector and replaced it..... however bonehead move I think I crossed the wires and it became pretty obvious what I did. With a test start the motor began idling erratically. I quickly shut her down and corrected the wire cross. Installed the connector back and things appear to run fine however I now have an engine error code indicating a Vanos fault on this exhaust VANOS and it will not go away. Tonight I replaced the Vanos valve on the exhaust side and still the code persist. I'm wondering did I somehow screw up the timing or perhaps even the ECU when I crossed those wires?
Old Feb 23, 2021 | 09:15 PM
MiniToBe's Avatar
MiniToBe
Did the wires touch each other and did you notice a spark?
The vanos solenoid is just a coil and I'm not sure if it's polarity sensitive.
Usually with a more sophisticated software, you can test and read the value.
also, it might be worth checking the timing and chain.
Old Oct 5, 2022 | 06:38 AM
papermaker's Avatar
papermaker
I second the question if crossing the wires has an impact on the ECU that is permanent or repairable. In my struggles I can not seem to get the ECU to talk to the solenoid valve. 2012 Mini Cooper LCI N16 code 2842 Vanos Valve Exhaust Activation - North American Motoring
Bleednedge
Mar 24, 2019 10:21 PM
MrSurly
Aug 29, 2018 04:44 PM
RandyD
May 14, 2018 06:43 AM
proscia116
Jun 8, 2015 06:20 AM
kentuckynet
Mar 8, 2013 01:59 PM
