JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
2009 JCW rebuild
Old Feb 21, 2021 | 08:27 PM
svt_vic's Avatar
svt_vic
2009 JCW rebuild block question?
Hello! newb here to this mini world. As far as some of my research goes its to my understanding N14 are turbos correct?
I have a 09 pepper white mini JCW. Cylinder 4 wall scored due to plug melting a hole on top of piston. Cylinder head is ok. My intention are to find a short block for it. So will I be good with any R56 N14 block just as long as it’s out of a cooper S? Or does it Necessarily need to be from JCW block?
if so what are the differences?
ive herd the head is different along with valves. But I figure the bottom end would be the same for both, unless the JCW is built different. I’m new to all this and just want to make sure I buy the correct things. TIA!
Old Feb 22, 2021 | 09:36 AM
oldbrokenwind's Avatar
oldbrokenwind
Yes, N14 imply's a turbo. JCW has 10.0:1 CR while the S has 10.5:1 CR, so pistons are different. Possibly other differences too. If you're the original owner, or at least know how the engine has been maintained, I'd recommend keeping this block and boring out the cylinders to 77.5mm for new pistons. Any short block will be an unknown and a big risk.
Boogers
Mar 23, 2021 07:24 AM
csllover
Oct 14, 2017 05:44 PM
GunRuBandits65
Oct 2, 2017 06:03 PM
tag1260
Sep 13, 2017 08:20 PM
jbd5015
May 11, 2015 02:48 PM
