R52 Exterior car cover
just take the ant' off when you use the cover ... you'll find a 'plain' cover for a hardtop will work
or get a stubby ant'
from my experience with covers, a pocket for a regular ant' will probably result in a broken ant' b4 long
Thanks for your suggestion. I have been using a cover that had the stock antenna pocket. Any other covers bent the existing antenna. And although the antenna didn’t break, the seams around the antenna base eventually split. Your suggestion may be the only way to go.
R50/53 Car Cover - Testimonials?
Good-Karma
Dec 4, 2006 11:55 AM
