Suspension Question on H-Sport rear camber arms
Old Jan 1, 2005 | 01:19 AM
S1monLM's Avatar
S1monLM
How many arms do I have to replace, I thought there are only 2 lower arms?
Old Jan 1, 2005 | 06:10 AM
Brain1.0's Avatar
Brain1.0
Manufacturer
there are 2 lower arms and 2 upper arms, most of the time you are trying to remove negative camber and only need to replace the lower arms.
So depending on why you are changing your arms it could be 2 or 4, I only did the lower arms on mine and I think that most people only do the lowers.
Old Jan 1, 2005 | 08:02 AM
gowest's Avatar
gowest
You only need to replace the lower arms to make camber adj. and toe is adj. at the front of the trailing arm but replacing both pairs of arms will make your toe adjustable at the arms as well and most alignment places would rather do it there, as it's easier to make fine adjustments and that's assumeing they can even find the stock adjustment point which requires loosening 6 bolts prying, measuring, prying , measuring, prying, measuring ect. Also all the after market arms are stronger than the oem arms and by having four instead of two you will be able to change your rear track, move both wheels in or out. Many people with tall tires, wide tires or wheels with non stock offsets that have rear rubbing could benefit from that. To be autocross legal you need to get arms like the H-Sports though and they all look better.
W0TM8
Dec 19, 2019 07:50 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
