R60 2014 Countryman S Transmission Fluid Fill Tool - Need correct part
My wife drives a 2014 Countryman S w/auto trans. It's started to shift a little hard, so I was going to change the transmission fluid. I searched this forum and found quite a few threads. Decided not to deal with dropping the pan at this time. It looks to be a much bigger PITA than I'm use to working on my Jeeps. So I figured I'll start with a drain and fill. Found a reference to a fill tool in one o the threads and ordered it. Was able to drain 2.5 quarts and started to refill when I discovered that the threaded end of the fill tool was too large. So now I'm scrambling to find the proper fill tool. Does anyone have a direct link they can provide to one that worked for them? Thanks.
Better late than never. Just wanted to confirm that one of the pipes in that set works. It's actually the straight, longer threaded one. With a simple pump for a quart bottle, this setup makes it quick and easy to cycle newer transmission fluid in.
How did that change go? fix the issue?
entropy1
Aug 11, 2018 09:32 PM
davidg5700
R55 :: Clubman Talk (2008+)
Aug 6, 2016 06:25 AM
boognish
May 11, 2014 09:18 AM
