R60 2014 Countryman S Transmission Fluid Fill Tool - Need correct part
Old Jan 5, 2021 | 06:02 PM
Michael Duke's Avatar
Michael Duke
My wife drives a 2014 Countryman S w/auto trans. It's started to shift a little hard, so I was going to change the transmission fluid. I searched this forum and found quite a few threads. Decided not to deal with dropping the pan at this time. It looks to be a much bigger PITA than I'm use to working on my Jeeps. So I figured I'll start with a drain and fill. Found a reference to a fill tool in one o the threads and ordered it. Was able to drain 2.5 quarts and started to refill when I discovered that the threaded end of the fill tool was too large. So now I'm scrambling to find the proper fill tool. Does anyone have a direct link they can provide to one that worked for them? Thanks.
Old Jan 5, 2021 | 09:18 PM
zcspec's Avatar
zcspec
Hey Michael, a FB member told me to buy the following:
Amazon Amazon
During my complete transmission drain and fill, I actually filled from the fill bolt.
Old Jan 5, 2021 | 09:27 PM
Michael Duke
Thanks. I ordered it. I will update this thread after I get it so anyone else who isn’t sure can use your link.
Old Aug 29, 2021 | 01:04 AM
Michael Duke
Better late than never. Just wanted to confirm that one of the pipes in that set works. It's actually the straight, longer threaded one. With a simple pump for a quart bottle, this setup makes it quick and easy to cycle newer transmission fluid in.
Old Aug 29, 2021 | 08:43 PM
zcspec's Avatar
zcspec
Thanks for the update Michael!
Old Jan 15, 2022 | 11:56 AM
stiksandstones's Avatar
stiksandstones
How did that change go? fix the issue?
entropy1
Aug 11, 2018 09:32 PM
davidg5700
R55 :: Clubman Talk (2008+)
Aug 6, 2016 06:25 AM
boognish
May 11, 2014 09:18 AM
mikeeminis06
Apr 29, 2014 07:10 PM
Jon L
12
Oct 6, 2012 03:57 AM
