R50/53 Cracked fuel filter housing causing lean condition?
Old Dec 27, 2020 | 02:56 PM
GonnaMini's Avatar
GonnaMini
I’m chasing down a lean condition on a ‘05 R53. When I went to check the fuel filter I noticed there was gas pooling in the crevices of the cap on the filter housing. There were also small cracks which I assume is where the leak is coming from. Could this be cause a lean condition? Is the filter downstream or upstream from the pump?
Old Dec 27, 2020 | 05:27 PM
ghostwrench's Avatar
ghostwrench
As a data point, I had a cracked fuel filter housing that did not result in a check engine light or lean condition. My only issue was the smell of gasoline from the gasoline pooling on top like you describe.
Theoretically, it's possible there could be a fuel delivery issue. I would suggest replace the housing - because leaking gasoline is never good, then evaluate afterward.
Old Dec 27, 2020 | 06:06 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
So many of us have, upon changing out the fuel filter, have gotten a "no start" condition until the fuel filter gasket was properly fitted. I would think that, if there were sufficient leakage, you'd get a similar reaction. Nevertheless, I'd certainly remedy the fuel leakage, especially considering the close proximity of electrical connections.
Old Dec 27, 2020 | 06:12 PM
GonnaMini's Avatar
GonnaMini
The part has been ordered. Hope this fixes the issue.
guspi76
Feb 6, 2019 09:28 PM
frankiev
Jul 19, 2018 09:35 AM
axsys
Oct 7, 2014 11:00 AM
friuli
Cooper (non S)
Dec 30, 2006 03:04 PM
