R50/53 +2 ATI crank pulley
Old Dec 18, 2020 | 07:07 PM
cooper48's Avatar
cooper48
+2 ATI crank pulley
Hi, folks. For those running a +2 ATI crank pulley, did you find it necessary to swap the alternator pulley to prevent it from overcharging due to increased RPMs? Thanks.
Old Dec 18, 2020 | 07:56 PM
Mini_Crazy's Avatar
Mini_Crazy
No.
+2% at 7000RPM would only be equivalent to 7140 RPM . . . not enough to worry about.
Old Dec 18, 2020 | 09:09 PM
jk6672's Avatar
jk6672
I didn’t notice any adverse effects.
Old Dec 19, 2020 | 01:48 PM
cooper48's Avatar
cooper48
Mini_Crazy, nice mods. Have you dynoed it? If so, please share.
Old Dec 19, 2020 | 03:07 PM
mountainhorse's Avatar
mountainhorse
It’s an alternator with a regulator ... rpm would not have an effect on ‘overcharging’ ... the battery and system will only draw as many amps, up to the capacity of the alternator, as it can use.
FWIW
Edit: Too LOWof RPM WILL Affect your output tho... which will not be the case with the OP’s situation.
Old Dec 19, 2020 | 09:19 PM
Mini_Crazy's Avatar
Mini_Crazy
285hp
285HP@7500 RPM, with a very flat torque curve: more than 210 foot pounds from 3500 to 7000 RPM. Perfect for street, with the occasional track-day. In understated Brit-speak, acceleration is brisk.
With a different cam, 300HP is very doable, but it would cost me the low-end torque needed to survive occasional stop & go traffic on steep hills with a clutch.
Old Dec 22, 2020 | 07:01 AM
nd-photo.nl's Avatar
nd-photo.nl
Some input from someone with a less extreme setup. I have the the 2% overdrive version with a JCW 11% pulley. Idling is just that bit better and I believe the aircon works a little better when idling.
It's a quality part and highly recommended. A lot of money, but worth the upgrade for me. I received a faulty one first, but it was replaced immediately by the seller.
More pics in my build thread (see signature)
Old Dec 28, 2020 | 05:36 PM
Serafin's Avatar
Serafin
i have 17% SC and 2% crank, all good on my end.. no issues
Old Dec 29, 2020 | 06:33 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've installed hundreds of the 2% dampers and never needed to install a larger alternator pulley. The ECU controls the Alternator with regulator so it will automatically reduce the charge as necessary so you don't have to change the pulley or worry about overcharging.
It is also a great mod to add to a stock JCW to get just a little bump in power and keep it all JCW. I run this on my GP 1
We keep the 2% in stock too
https://www.waymotorworks.com/super-...ulley-r53.html
Old Dec 29, 2020 | 06:55 PM
steve05ram360's Avatar
steve05ram360
I picked up my ATI from you guys (standard diam) and was really surprised at how fast it arrived. Install happened in November... (iirc, its all a blur lol)
Old Dec 29, 2020 | 08:32 PM
RB-MINI's Avatar
RB-MINI
FWIW, due the minimum size of the hub, center, or what ever it’s called, the “standard” ATI is actually about .8% bigger than stock so your boost should also slightly increase with one. Not sure why they just don’t market them as 1% or 2%.
alconk
Jun 19, 2019 07:37 PM
Saltysalt
Jul 23, 2013 05:23 PM
//MiniMonster//
May 18, 2008 03:54 PM
SORMINI
May 25, 2006 12:10 PM
