R50/53 Map sensor bad?
Old Dec 15, 2020 | 09:34 AM
alconk's Avatar
alconk
Map sensor bad?
A few days ago I posted that I noticed my car was down on power and thought it was due to the gas I put in it. Well it wasn’t, last night my cel came on and when checked it came up Manifold pressure sensor high voltage or something like that. Could that be causing the problem?
Also with it being cold out I can get 20 psi of boost with my mods and my DSC light comes on too when I hit that boost level.
Old Dec 15, 2020 | 12:02 PM
IQRaceworks's Avatar
IQRaceworks
20psi? What size pulley are you running?
Old Dec 15, 2020 | 01:22 PM
A383Wing's Avatar
A383Wing
I had a similar issue with my "06 JCW....mine turned out to be a bad T-Map sensor that is attached to the intake manifold right behind the radiator.
Bryan
Old Dec 15, 2020 | 01:39 PM
alconk's Avatar
alconk
16% with a 2% od ATI crank pulley
Old Dec 15, 2020 | 01:40 PM
alconk's Avatar
alconk
Bryan
yes it must be bad, cleared cod and came back when I got into the boost again. PO 107 map input low.
Old Dec 15, 2020 | 02:31 PM
A383Wing's Avatar
A383Wing
and I bet the DSC light came on as well
Bryan
Old Dec 16, 2020 | 05:00 AM
IQRaceworks
Seems high for the crank/SC pulley you are running. How are you measuring boost?
Old Dec 16, 2020 | 07:14 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
stock ecu cant handle that much boost, and it shouldnt be that high with just those mods
I've had map sensors fail on both my cars, but only the one on the intake, never the tmap
Old Dec 16, 2020 | 12:58 PM
A383Wing's Avatar
A383Wing
The T-Map sensor is the one bolted to the aluminum intake....the regular Map sensor is down by the thermostat
Bryan
Old Dec 16, 2020 | 09:28 PM
adriancl's Avatar
adriancl
I think it should check your cathalyst,it may be broken and the exhaust gas may be blocked,this leads to a large increase in the intake pressure.
ingsoc
Apr 21, 2026 08:36 PM
Eric Link
Aug 6, 2015 02:21 PM
SPRINTCARS
R60/61 Cooper S Drivetrain
Nov 13, 2013 07:50 PM
genik
Jul 24, 2013 09:19 PM
MSFIT
Feb 17, 2012 01:46 PM
