F56 GP Tuning
Old Nov 27, 2020 | 04:35 PM
joselibos@me.com's Avatar
joselibos@me.com
F56 GP Tuning
Hello guys I’m new here. I installed the JCW Pro exhaust on my GP and woow. That’s how the car should have come from factory. The stock exhaust sounds like a lawn mower. My leaf blower sounds better then the stock exhaust. I also just installed the Millitek DP and woow what a changer.
So now the question. Have any of you thought about tuning the car? I am inclined for a JB4 for now. Any thoughts?
Old Mar 20, 2021 | 04:53 AM
KYDan's Avatar
KYDan
Yes, it is a wonderful addition, the sound is awesome. The next step is to put it on a dyno to see if the JCW PRO exhaust adds any horsepower and torque to the GP. It really does not need more horsepower as you can't adequately use what it is has stock with the factory setup. Still, it is a fun car to drive and with the throaty sound with the pro exhaust it is a great backroads speedster.
Old Mar 21, 2021 | 09:48 PM
Clutch Wotan's Avatar
Clutch Wotan
When testing, the difference is around 17 hp difference when open to closed ;-)
Old May 21, 2021 | 05:16 PM
scottab36's Avatar
scottab36
Has anyone tried the NM Engineering tuning box?
https://nm-eng.com/collections/mini-...odule-nm648846
Old Aug 6, 2021 | 03:27 PM
TheGeekGuy's Avatar
TheGeekGuy
Fitted to my car yesterday. I have it on mode 2 (Race Mode). There is a "hiccup" at lower throttle settings. I will flipping to mode 1 tomorrow to see if it goes away. Here is a write up I did awhile ago comparing the NM Engineering Module and the Racechip:
https://www.northamericanmotoring.co...-racechip.html
Old Jul 22, 2022 | 06:01 PM
EriGp3's Avatar
EriGp3
did you get the jb4?
any updates on tuning?
Old Aug 23, 2022 | 06:10 AM
benben01's Avatar
benben01
Is BM3 flash compatible on the GP3? If so, can we get someone to work on a map for it? Happy to chip in for the time and effort especially if we can get a group buy setup.
Old Aug 23, 2022 | 08:51 PM
dbturbo2's Avatar
dbturbo2
Happy to help as well, would love an adjustable burble tune.
Old Aug 24, 2022 | 03:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
@Lou@Prototype-R has done tuning in 3rd gen F56s, but not sure if he’s done any GP3s. Maybe shoot him a quick note?
Old Aug 24, 2022 | 06:34 PM
dbturbo2's Avatar
dbturbo2
Thanks, sent an inquiry to Lou.
Old Aug 25, 2022 | 07:17 AM
Hellokitty90's Avatar
Hellokitty90
Any luck?
Old Aug 25, 2022 | 07:35 AM
benben01's Avatar
benben01
Leaning towards JB4 if we get no love on a BM3 or flash tune. For the power level bump, I think JB4 is ideal for 40-50HP bump on a plug and play piggyback that does not touch the ECU.
Old Aug 25, 2022 | 09:46 PM
dbturbo2's Avatar
dbturbo2
Originally Posted by Hellokitty90
Any luck?
His reply was “Yes we can tune the GP3 but unfortunately do not have a remote tuning solution for it as yet.’
Sent a follow up with regards to a possible timetable for the remote solution and will share what I hear.
Old Aug 26, 2022 | 08:14 AM
benben01's Avatar
benben01
Did he say what platform he's using for the tune?
Old Aug 26, 2022 | 10:55 AM
dbturbo2's Avatar
dbturbo2
No he did not.
Old Aug 27, 2022 | 08:12 PM
Hellokitty90
No he did not.
After more research, it looks like they must be using FEMTO Evo. This is required to beat the Bosch DME lock on post June 2020 cars.
https://femtool.com/femto/
https://www.pp-performance.de/en/tun...l-turbo-306ps/
Old Aug 31, 2022 | 06:15 AM
benben01's Avatar
benben01
Update as well.. Reached out to DME tuning in NJ.. Cost is $3K and they will ship DME to FEMTO to unlock and then do the customized tuning locally. Unless the direct tuning from FEMTO is cost effective, think JB4 is the way to go for some additional ponies.
Old Aug 31, 2022 | 06:38 AM
Hellokitty90
Check your VIN. Is your car a June 2020+ car? If not, you could get the ECU bench unlocked locally and it would be cheaper. Once unlocked, you could use something like MG Flasher to flash an OTS map for around $500.
FEMTO’s unlock by itself is like $1,000. DME Tuning is highly respected as they are one of the few companies that can crack and tune ECUs for Ferris and Lambos. That is why their “custom tunes” are so expensive.
Old Aug 31, 2022 | 06:44 AM
benben01's Avatar
benben01
Cool.. Will take a look later today. I am pretty sure is it's going to be after June 2020 as our car # is 2972
Old Aug 31, 2022 | 07:03 AM
Hellokitty90
I am certain it is. Mine is #200X and it was produced in June 2020.
Old Jan 17, 2023 | 04:37 PM
scottab36's Avatar
scottab36
It's been a minute since I've posted here but do have an update. I'm running the Eventuri intake, AIRTEK intercooler and the NM-Engineering module. The module is set on low. I will NEVER set it to high. With this combination on the DYNO in May the GP3 came in at 340WHP and 343 ft lbs for torque.
Pros: Crazy fun to drive but only in temperatures above 65F. Set the cruise at 70MPH and you will get 40MPG all day long. Excellent road trip MINI due to how comfortable the seats are. Logged 4,260 miles with MINI Takes the States. The ability to completely crush an M3 on The Dragon is hilarious. Also the GP3 lives for The Dragon. Make sure you drive it in GP Mode!!
Cons: No real traction below 60F with the Ventus tires. Scary understeer at temps below 50F. Launch control is pretty much useless as the tire just smoke off the line. You will pedal the throttle a lot when taking off with hard acceleration. The Ventus tires are one season tires, meaning they'll last one season. City driving lowers the MPG to around 22-24 MPG.
Old Jan 17, 2023 | 05:53 PM
Hellokitty90
I had the same issue with traction. I upgraded to Nankang CRS 235/40/18 on stock wheels and it solved the traction issue completely. You can also add 12mm spacers all around for a perfect flush fitment with no rubbing.
The OE Hankooks are TRASH.
Old Jan 17, 2023 | 06:29 PM
benben01's Avatar
benben01
I am running 245/35/18 Michelin Pilot AS4+ on 18x8.5 Enkeis.. No more torque steer and lots of all weather traction
Old Jan 18, 2023 | 03:55 PM
scottab36's Avatar
scottab36
I have no issue with the Hankooks. They do exactly what they're designed for on the GP3. I tried others but quickly realized that the reason I lost torque steer is because I lost the grip of the Ventus tires. I also lost braking ability. I'm not willing to add the unsprung weight of larger tires as that affects overall braking, handling and power. Also not interested in changing the geometry of the suspension by adding spacers, which also adds addition unsprung weight.
I've never had a performance issue with the Hankooks. Not a single slip, slide or break in traction when operating under the proper conditions. Keeping in mind that the Hankook Ventus tires are summer only so once the temperature drops the performance of the tires is greatly affected. You must know the limitations of the GP3 with respect the the road and weather conditions.
This was not known by a driver in New Hampshire back in October 2022 which resulted in the loss of both the driver and GP3. :(
Old Dec 21, 2025 | 05:36 PM
blue al's Avatar
blue al
Bump as must be some tuned GP’s around by now
