Suspension Megan Racing Lowering Springs
Old Nov 17, 2020 | 08:42 AM
Dmads's Avatar
Dmads
Does anyone have any experience with Megan Racing Lowering Springs?
These springs lower the car in the front: 0.5in and in the rear: 0.75in
I was thinking about pairing them with the Bilstein B8 SP Sports Shocks Kit.
What else would I need to lower a stock r56?
I'll take all the advice I can get and any recommendations if these aren't good springs/shocks.
Old Nov 18, 2020 | 03:55 PM
3lusive's Avatar
3lusive
I found this thread about megan racing springs, take the info here as you will https://www.northamericanmotoring.co...g-springs.html
Personally I have the koni yellow + nm engineering springs, great combo
Can't really go wrong with nm engineering springs with the b8's i would guess. When lowering you'd probably want to get adjustable sway bar end links to avoid preload on the sway bars. And maybe adjustable rear lower control arms to manage the rear camber.
Old Nov 18, 2020 | 05:12 PM
Dmads's Avatar
Dmads
Thanks for the information! I keep hearing about the nm engineering springs.. Do you think that 1.2in drop would be too much for a Minnesota winter?
and you would recommend the koni yellows?
Old Nov 19, 2020 | 09:46 AM
3lusive's Avatar
3lusive
Koni yellows are awesome on twisty roads and the track, feels much more planted and responsive. However the ride quality is kinda bad on Cali highways and bad roads...some of the potholes and expansion joints really sound bad. Adjusting the front softness is straightforward but you'd have to remove the rear shocks to adjust, so I haven't done that at all.
Hard to say if it would be too much of a drop for winter, MINIs are kinda low already so we already snow plow
Old Nov 19, 2020 | 10:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Megan springs are inexpensive, and the paint will maybe chip sooner than some more expensive options. Pretty mild as far as lowering goes.
For driving in winter? Depends on your driving style. I daily drove a lowered Miata for 4 years through winters in Connecticut, some winters with feet of snow on the ground. A good set of snow tires, and I wasn't going to get stuck, and I could drive circles around any SUV with all season tires. Now, I'm driving an R55 Clubman through Western NY winters lowered significantly on Megan Racing coilovers.
If I were you, and wanted minimal lowering, but a performance suspension, I would go with the Bilstein Cup kit:
https://www.ecstuning.com/b-bilstein...46-180469~bil/
https://www.ecstuning.com/b-assemble...31306772749kt/
Old Nov 19, 2020 | 10:31 AM
Dmads's Avatar
Dmads
I like the idea of going with the kit: https://www.ecstuning.com/b-bilstein...46-180469~bil/
is there anything less expensive? The only reason I'm asking is because I'm not really looking for huge performance improvements. More so for the aesthetic purposes
Old Nov 19, 2020 | 11:26 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If you are only going for looks and cheap, the Godspeed springs are even less expensive than the Megan Racing...
https://www.ecstuning.com/b-godspeed...ts-mc-0001~go/
Get those, put them on your existing struts, and go.
Old Nov 19, 2020 | 01:12 PM
3lusive's Avatar
3lusive
+1 if only for looks then you would be fine with springs only
Old Nov 19, 2020 | 03:00 PM
Dmads's Avatar
Dmads
I don't want to cause any premature wear and tear on my car because of using lowering springs with stock shocks.
Old Nov 19, 2020 | 05:21 PM
blkkouki's Avatar
blkkouki
I have Megan racing springs on my r53 they are definitely good for the money. I’ve put them on several other cars over the years and I’ve never had any issues .
Old Nov 19, 2020 | 06:41 PM
Dmads's Avatar
Dmads
what shocks would you pair with the megan racing springs?
Old Nov 20, 2020 | 03:28 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Seriously, just get the Bilstein kit, along with the install kit from ECS, and you’ll be done
Old Nov 20, 2020 | 10:48 PM
Dmads's Avatar
Dmads
Thats what I'm going with
sani
Suspension
Nov 19, 2020 08:15 PM
dannyhavok
Suspension
May 16, 2011 04:42 AM
Applellial
Suspension
Mar 14, 2011 01:08 PM
Maaij
Suspension
Jul 5, 2006 07:05 AM
Bahamabart
Suspension
Oct 20, 2005 07:07 AM
