Thoughts on 215/40/18 Non-RF on a OEM Rim?
Old Oct 22, 2020 | 06:13 PM
jpsjr1970's Avatar
jpsjr1970
Does it work? Any issues? Jose
Old Oct 23, 2020 | 07:39 AM
NBCGLX's Avatar
NBCGLX
215/40-18 should be fine on an OEM wheel. I’m running 215/45-17 on OEM 17” wheels
without issue. I’ve heard that 225 can lead to rubbing in the front, so I wouldn’t go any wider than 215, and stick to the factory sidewall ratio as you’ve suggested.
Old Oct 23, 2020 | 08:44 AM
jpsjr1970's Avatar
jpsjr1970
Thanks Pal! Will do! Jose
Old Oct 23, 2020 | 09:19 AM
ghstrdr's Avatar
ghstrdr
I'm running 215/40/18 ..............................
Old Oct 25, 2020 | 01:41 PM
rtowell's Avatar
rtowell
Just a word of caution. Do your research on tire width ... Tire Rack is an excellent source. I found that the Continental ExtremeContact Sport rubbed slightly on the front struts. When I checked the spects, they were just slightly wider than most of the other tires of the same size. My experience is that the 215 width will probably fit, but not necessarily all brands and models.
Old Nov 30, 2020 | 05:29 AM
jpsjr1970's Avatar
jpsjr1970
So I decided to go with the New MICHELIN PILOT SPORT AS4 215/40ZR18 89Y XL BSW UHP ALL SEASON TIRE. So far I’m really happy with the quietness and the handling. When I went to a new set of OEM Mini JCW Wheel/Tire setup, the Pirelli’s really are an amazing piece of crap! In the 3k miles I put on them I replaced 2 due to bubbles and found an additional 6 more bubbles on the inner side walls of them. No more runflats for me, I’ll get the emergency roadside kit and move forward. I’ll put on my winter set next weekend.
enoe01
Feb 11, 2016 06:08 PM
sonnysu
Factory JCW Talk (2009+)
Apr 15, 2009 02:55 AM
danielo
Tires, Wheels, & Brakes
Feb 22, 2009 09:42 AM
J_D
Jan 18, 2008 09:08 PM
