R50/53 Rocker panel rot
Old Oct 16, 2020 | 05:09 PM
steve05ram360's Avatar
steve05ram360
Rocker panel rot
Why the rocker panels rot on some cars... Working on the new belt & 17% pulley, pulled the wheel liner and had a peek down the rocker panel... full of dirt & debris. Cleaned out has much as I could but it is still not ideal in there.
The correct fix is to pull all 4 liners, (I am guessing the liner closes off the other end), clean it all out with pressurized water, let it dry and then (optional) treat it as much as possible with Fluid Film. This is the stuff I mentioned in another thread, The gunk that is getting back there will stay wet for a long time, couple in road salts & de-icers and it will eat away at that area where it sits. If there is no mud or debris to hold it moist, it will dry up and should be OK.
The 3rd Gen Ram owners (and most trucks) all have the same exact problem with the areas above the rear wheels, garbage gets back there and traps moisture. The cleaning & fluid film extends the life significantly.
Old Oct 23, 2020 | 07:48 AM
MINI_42's Avatar
MINI_42
Thank you!
Old Oct 23, 2020 | 09:01 AM
steve05ram360
FWIW, here are 2 threads from the Ram side that discusses the issues
https://www.cumminsforum.com/threads...-pics.1307321/
https://www.cumminsforum.com/threads...inter.1636698/
Old Oct 24, 2020 | 10:20 AM
nd-photo.nl's Avatar
nd-photo.nl
Good tips Steve!
azeli73
Jul 15, 2020 07:04 AM
trvlnagain
Aug 20, 2010 06:39 PM
stratman977
Classic Mini Talk
Mar 25, 2008 05:30 PM
stratman977
Classic Mini Talk
Dec 2, 2007 06:25 AM
El_Jefe
Detailing 101
12
Sep 6, 2006 10:47 AM
