Drivetrain Best Tuning Software
Old Oct 6, 2020 | 11:06 AM
cut7's Avatar
cut7
Gentlemen (& Ladies too),
I am looking for opinions on what is the best tuning software package. I am interested in first-hand opinions, so please tell of your experiences with a particular software. I have tuned many ECUs in the past (not Minis, however) so complexity doesn't bother me. For me, the more options, the better!
I want to hear constructive feedback.
And...GO!
Old Oct 7, 2020 | 06:56 AM
r53racer's Avatar
r53racer
I have experience with Bytetronik and Adrian's tune. I would say Bytetronik is very flexible in such that mappings can be changed, if you are knowledgeable. As for my experience with Adrian, he was able to use my Bytetronik software to correct/fix the bad mappings I got when I purchased canned tunes from Bytetronik. He manually changed the values through AnyDesk remote, and then I loaded his edits using the bytetronik. Also, Bytetronik allows logging, see attached. Adrians tuning is very good, the car pulls stronger and is a lot smoother after.
File Type: csv
Old Oct 7, 2020 | 07:19 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
winols is probably the best, but you need a map pack for your ecu version, mini has many and the map addresses are different for each one.
Very few have the map packs / DAMOS files or documentation, the stock ecu is very complicated and I'm not aware of anyone that sells them
Old Oct 7, 2020 | 07:39 PM
putttn's Avatar
putttn
Link is another one used by many folks here.
Old Oct 7, 2020 | 08:02 PM
cut7's Avatar
cut7
Link software only works on their ECU. I'm looking for something that will work on the stock ECU.
Old Nov 1, 2020 | 10:42 AM
Errk's Avatar
Errk
I have also only heard good things about Adrian’s tunes.
IQRaceworks
18
Jan 25, 2019 04:45 AM
r56Ter-Bow
Mar 19, 2013 06:29 PM
heresmymind
Mar 18, 2013 06:38 PM
thanosman
Feb 12, 2010 07:12 AM
