R56 OBD Communications Fail @DMV
Old Sep 15, 2020 | 03:41 PM
Struns's Avatar
Struns
Found thread on "OBD Not Ready" but that does not seem to be problem. Car driven regularly, no maintenance in past 8 months except oil change. Battery has not been disconnected and when I plug in scanner it communicates fine...no codes. What's the problem?
2009 S R56 87kmiles
TIA
Old Sep 15, 2020 | 04:52 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I assume you are going in for your annual vehicle inspection? If the DMV is failing your inspection, didn’t they tell you why?
Old Sep 15, 2020 | 05:10 PM
Struns's Avatar
Struns
Well in NJ it's every two years.
Vehicle Inspection Report:
Bulb check: Pass
Check Engine light On: Pass
OBD Connector: Pass
OBD Communications : Fail
Old Sep 15, 2020 | 05:28 PM
Jason Cornelius's Avatar
Jason Cornelius
I have noticed with mine that I can’t get it to read when I press the start button w/o the clutch in. I have to start the car first, then turn it off then start w/o clutch and boom she works. I’m in Ohio, we don’t test here, but that is what I have to do to read or clear a code.
mcaanda
Aug 5, 2019 10:12 AM
mschandler76
May 5, 2018 10:25 AM
blackprophet
R55 :: Clubman Talk (2008+)
Jul 31, 2016 12:53 PM
papawhiskey
Dec 14, 2015 01:10 PM
jcap287
Jan 5, 2008 10:00 PM
