SMF (Street Modified FWD) Been awhile, but the Mini is doing well! Fully forged now with Ko4 turbo
Old Sep 14, 2020 | 06:14 AM
jetsr6's Avatar
jetsr6
Mod list
2007 Mini Cooper S
Ok here is the new setup
N14
K1 rods
CP 10.5 77.5 pistons
ARP everything
Cyro timing chain kit
ACL race bearings
Supertech Ti retainers
Beehive valve springs
Cat cams #1302603 sport
Jmtc s42 turbo converted to Ko4
Hfs3 Aquamist water injection
Custom short K&N intake
G-plus oil cooler with thermostat
Wotbox
RPM Stage 3plus tune done by Mario Amsoil dominator 10w40 mixed
Amsoil 80w90 gear oil for transmission
-Custom short K&N typhoon cold air intake
-46.4billet extended tip compressor wheel Ko4 turbo
-Kompack dual port blow off valve
-3 inch downpipe
-Custom straight midpipe
-12”resonator
-Alta intercooler
-HFS3 Aquamist water injection (best idea)
-2019-BC racing coilovers with Swift Springs, revalved by RedShift to give better dampening. Stiffer compression, lighter rebound.
-25mm hollow rear sway bar set to stiffest setting
-Hawk HP Plus pads rear
-2019-Wilwood Big Break Kit (front) 4 pot (4 stainless steel pistons to compress brake pads)
-Hoosier A7 tires 275/35r17 front 225/45r17 rear
-Powerflex bushings throughout
-3J driveline LSD, clutch type
-OS Gliken str flywheel and clutch
-Mario RPM stage 3 tune
-GoNMF oil additive
New for 2018 big wing and carbon fiber sunroof replacement.
This was done spread out over a year
A lot of weight reduction- 2300 (2075 class minimum)
Old Sep 14, 2020 | 06:44 AM
jetsr6's Avatar
jetsr6
FTD and top PAX
scotty_r56s
Sep 22, 2021 02:57 AM
jetsr6
SCCA Solo and ProSolo
Nov 23, 2018 09:35 AM
jetsr6
Nov 8, 2017 10:41 AM
The Flying Pig
Sep 18, 2017 12:54 PM
bisnitch
May 1, 2015 02:15 PM
