R56 Vinstar Halo Fog Lights
Old Aug 27, 2020 | 09:35 AM
Dmads's Avatar
Dmads
Does anyone have experience with these fog lights? I'm wondering if these will be plug and play or if they will require any extra wiring.
https://www.ecstuning.com/b-vinstar-...-r56-v3-cl~vi/
Old Aug 27, 2020 | 09:47 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
They will require extra wiring. You will have to install the control box for the DRL ring.
Old Aug 27, 2020 | 10:03 AM
Dmads's Avatar
Dmads
Thanks for you reply, do you know of any halo DRL fog lights that won't require any extra wiring? I have fog lights with the top section of the fog light always on and a switch inside the car to turn the rest of the fog light on.
Old Aug 27, 2020 | 10:28 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Halo DRL? No. The stock lights with plug-n-play LED bulbs would be the best option for no additional wiring.
Old Aug 27, 2020 | 01:58 PM
Kupona's Avatar
Kupona
I just installed their V3 kit, lemme tell you exactly what you need to do. Remove bumper. Move OEM plastic fog housing rings to new housings. Attach to bumper. Connect pigtail from Vinstar housings to pigtail connector coming from LED control box. Re-install your H8 fog bulbs (they will need a bit of force since the opening is a bit smaller). Find passenger DRL bulb socket that went into the OLD fog housing. Strip a small bit of casing on the white and blue striped wire (ACC power) and the brown wire (Ground). Use the splice modules included in the kit to connect the LED control box red wire to the blue and white striped wire and the black wire to the brown wire. The splices are super easy to do. Connect bump back up, turn on car, when you turn on accessory power for the lights the Halos will illuminate. Took me about hour and a half.
Old Oct 30, 2020 | 05:51 PM
Andy Wallbank's Avatar
Andy Wallbank
Did you have any error codes or overload on that circuit, instruction are vague but advise to wire straigt from the ACC on the fuse box. Im just about to instal but dont want to melt wires. Im presuming there is just 6 parking lights on this circuit to begin with at 5 w each (30w in total) or is there more. As you lose 10W by losing the old bulbs and add 13w, I doubt it makes a diffrence.
Old Oct 31, 2020 | 09:53 AM
I_Forge_KC's Avatar
I_Forge_KC
I run the sibling to these with the exposed LED ring. No issue with bulb warnings or over-currenting the wiring.
In fact, I also ditched the stock fog bulbs and instead am running Morimoto HID conversions at 55w each with no wiring issues.
Old Oct 31, 2020 | 11:33 AM
Andy Wallbank
Thanks for the response. Those look awesome, and so does the car! My 2012 R56 never came with fog lights from the factory, so i'm looking at way to get light to the fog light too, not the Halo.
This is what I had in mind, and seems the easiest way to use them. I was thinking of buy some cheap $20 H11 LED lamps of Amazon, with a 9W rating each, and wiring them to the high beam. At the moment the low beams are always on as DRL's along with the parking lights.
What would be the best way to wire these up? I want to avoid modules and switches etc, and just have them come on with the high beams, could I just use wire splice connectors to the positive feed of the high beam, or would i better off going back to the fuse box and using a relay.
Old Oct 31, 2020 | 03:32 PM
scottyb043's Avatar
scottyb043
Also running a set of the Vinster Fog/DRLs. Very happy with them.
Old Dec 16, 2020 | 08:14 PM
2015 Mini Black Ops's Avatar
2015 Mini Black Ops
I Forge, do you have a link to those drl/fog led's with the exposed LED ring? Thanks!
Old Dec 16, 2020 | 08:17 PM
I_Forge_KC's Avatar
I_Forge_KC
Here is a set:
https://www.ebay.com/itm/114464310680
Old Dec 17, 2020 | 03:32 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Forum sponsor:
https://www.outmotoring.com/led-fron...08+_wires.html
Old Dec 17, 2020 | 04:04 AM
I_Forge_KC's Avatar
I_Forge_KC
Thanks...? Never understood blind loyalty like this when the link shows Aaron doesn't even have them in stock and they are twice the price.
Old Dec 17, 2020 | 04:09 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I didn’t look at the stock status, and was just providing an option. Pretty sure all the different kits are made by the same Chinese factory anyway. Sometimes, I prefer to purchase from a reputable shop that offers a good return policy or warranty.
Old Dec 17, 2020 | 06:41 AM
We are direct with Vinstar and they dont have those anymore, just V3 linked at top, sorry. Some people just have what's left over.
https://www.ecstuning.com/b-vinstar-...l-r56-v3-clkt/
Old Dec 17, 2020 | 09:15 AM
2015 Mini Black Ops
Thanks for the links, guys! I am contacting the companies to see if they will fit in my 2015 MC 2 door hatchback. Happy Motoring!!
Old Dec 20, 2020 | 01:21 PM
If you have a F56 MINI Cooper Hatchback you need these: https://www.ecstuning.com/b-vinstar-.../v-130116~vin/
Those ones above are for the Gen 2 R55-R59 MINIs.
Old Jul 30, 2021 | 02:48 AM
mathy931's Avatar
mathy931
help :)
Could you elaborate on this. Did you connect DLR wires to only one bulb wires? What about the second socket, is hanging empty?
Old Jul 30, 2021 | 03:29 AM
mathy931's Avatar
mathy931
light ur way home
Also, does it work when u unlock the car? I meant that "light ur way home" function which works wit standard lights ?
Eclipseon
11
Mar 8, 2021 12:41 PM
protodon
Jun 2, 2009 06:06 PM
bond007
Aug 4, 2008 11:14 PM
jrprich
Electrical
30
Dec 18, 2007 11:19 AM
bpetzold
Electrical
Oct 30, 2006 03:47 PM
