R52 Rear speaker upgraded.. no bass
Are there any tips here? I put morel's in the front of my friends car and they have awesome punch, added same set to the rear and have no bass at all. I'm sure my hookups and tuning are correct - its a fully aftermarket setup with amps. Is it an airspace issue? The front of the speaker is near the panel, I removed the oem grills, and I reused the oem foam to seal it to the panel. Would it be possible to make a rear enclosure out of dynamat or something like that? Seems like maybe that big rear gap for the roof armature may be a bit too big and its too freeair?!
and you expect help here 'cuz??????? someone might GUESS your set up?????
Maybe I'M wrong but I'd expect little help here ..... I'm NOT an audio guy .....
the details of the setup are largely irrelevant. Its all good stuff. I just want to know if anyone had the same midbass problem and if they solved it. The problem is car-specific not audio specific. When the speakers were in the front they hit so hard I could feel it in the seat backs, the same speakers in the rear have no midbass.
I recently did an upgrade with a car audio shop. It seems that the rear speakers have 2 sets of wires going to them. Not sure why. One of them has LOTS of bass, the other, not so much. I suspect you've hooked up the latter.
Thanks for the reply, and thats good info. All of my wiring is new and directly wired to the amps, soldered to the speaker etc.. I'm sure its a car physics problem. the power and lines are all the same as when I had them hooked up front. I'm looking for suggestions on tightening up the midbass for the rear of the mini specifically. I will try dynamat and some sound deadening inside, but I was wondering if anyone had tried something else with good results.
In my case, I kept the HK system head unit and amp and replaced the front components and rear mid drivers with JL Audio CS series. It's VERY clear that the stock speakers were designed to work with the HK amp and DSP. My next step is to rip out the HK amp and stock head unit. That will fix my midrange suckout.
Can you elaborate what your setup consists of?
I built a system from the ground up in my previous R50 and it had great SQ.
I'm an audio guy, and would love to help 🙂
Thanks for the info. Are you using the factory wiring harness, or did you bypass it and run all new wire? It almost sounds as if one of them is out of phase - double check the wiring polarity of the rear speakers. Beyond that, you're probably right about it being the car. Maybe fabricate a rear baffle? Quite possible that the rear speaker cavity is larger than the door panel, and is affecting the overall Q of the driver.
With replies like these, that is for certain. Are all of your 6000 replies this useful?!
most ARE .. thanks for the tap ....
p.s. did you notice yet that there is a specific area for 'audio' ????
https://www.northamericanmotoring.co...-and-audio-14/
Lipofskyphoto
Feb 4, 2020 05:22 PM
Navigation & Audio Amplifying OEM rear speakers...?
bubblehelix
Dec 1, 2009 12:34 PM
Navigation & Audio Need pics or description of rear spkr grill removal
Kurtster
Dec 22, 2003 08:49 PM
