F57 Decel Popping
Decel Popping
Hi All - new to Mini and this forum. Recently purchased a '17 Cooper S Convertible and am annoyed with the Pirelli Run Flats it came with. I've read a bunch about the shortcomings of these tires and agree. The car does NOT handle like a go cart at all. Also, it is a manual, which I love, but I am getting lots of popping from the exhaust during decel. Just wanted to know if this was normal for this car. I don't think it has had any engine or exhaust work done to it. Thanks.
Ditching the run-flat tires is a pretty common "first mod". They're heavy, the ride is choppy at best, and handling suffers a bit, too (relative to non-run-flat tires). As for the burbles you're hearing, that's normal and one of the appeals of the MINI :-)
plenty of owners will have 'burble envy'
https://www.northamericanmotoring.co...m-farting.html
but I'll ask, are you using the sport mode?
If it burbles easily and not in SPORT I'd suspect the car has "a tune"
our 15 Roadster S never burbles .... probably cuz we NEVER engage SPORT ....... not our style . . .
"The car does NOT handle like a go cart at all..."
If your Mini does not handle like a "go cart at all"... then you have bigger issues than just the tires. Run flat tire technology has come a long way since 2001 and the 2017 Pirelli Run Flats are good tires. Changing them out for a different tire will not magically fix your Mini go cart problem.
I guess I will have to look into this a little more. Do you have any suggestions as to where to start? The car is pushing in the corners, and I have not had that experience with other front-wheel drive cars. I think one reason may be the light weight of the car, but it still does not seem right. Also, what pressure would you recommend for these tires? I am running 40 psi in them. Thanks - appreciate your input.
On the tire pressure topic, is there a reason to have a different pressure between the the run flats that came with the car versus non run flats or even new and improved run flats?
I recommend finding a similar MINI on a dealer lot and take a test drive to compare. My stock 06 pops on deceleration almost every time. (I would like it a little louder) It is part of the character of the MINI. As for the go cart handling, it is hard to say without comparing to other MINIs. It is too subjective to evaluate over the internet.
We can't judge the "handling" of your Mini. If you don't know anyone who's familiar with how they drive maybe go to a dealership and have a MA drive it and see what they think. I'd be hesitant to say that just getting non-RF tires is gonna make the difference, and it'll set you back $700 or so I bet (non-RFs are cheaper than RFs). When I switched from RFs to non-RFs on my 2007 MCS I thought it steered a tad better with the RFs although it definitely rode better with the non-RFs.
Drivetrain How can I stop my exhaust from "farting" ?
stylin99
Apr 23, 2005 07:40 AM
