R56 Passenger Side Water Leak
Old Aug 7, 2020 | 08:52 PM
Brayan Alanis's Avatar
Brayan Alanis
I have water is getting behind the door, pooling at the bottom, then coming over the weatherproofing strip on the bottom. How can I solve this issue. Its not the A Pillar it Sunroof drain . I have changed the door seal with another use one and I still have leaking.
Old Mar 26, 2023 | 08:21 AM
ptkacik's Avatar
ptkacik
What is the source? Have you tried putting paper towels in places where the water is entering. Even if they dry out, there will be evidence of water ingress.
good Luck,
Peter
Old Mar 26, 2023 | 10:06 AM
Yoshimura 1's Avatar
Yoshimura 1
Flush out the sunroof drain all kinds of dirt and things get trapped in there....What's the gap spacing on the door
Old Mar 29, 2023 | 09:45 AM
Make sure the side window is aligned and seals.
https://www.northamericanmotoring.co...djustment.html
https://www.realoem.com/bmw/enUS/sho...diagId=51_6223
Tool for gear adjustment : https://www.ecstuning.com/b-bav-auto.../b8800138~bav/
Sunroof drains - dont see any sunroof on that MINI.
holyspiritf56
Dec 30, 2019 09:31 AM
njaremka
May 20, 2019 04:17 PM
cupc4ke
Oct 8, 2018 07:02 AM
dewarner
Dec 14, 2017 10:15 AM
Flea77
R57 :: Cabrio Talk (2009+)
May 31, 2016 09:05 AM
