F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 P0446 Engine light.
Old Aug 5, 2020 | 05:23 PM
Thielepr's Avatar
Thielepr
P0446 Engine light.
I got the P0446 Engine code light. I verified the gas cap and got it again. I bought a new gas cap and cleared the light and 30 miles later the check engine light is on with the same code.
now the code is stored as a “permanent code” whatever that means.
any suggestions?
Old Aug 7, 2020 | 05:55 PM
whatstevedid's Avatar
whatstevedid
If you can get hold of ISTA+ run through the diagnostic and troubleshooting programmes on there. Could be a valve.
Old Jul 13, 2021 | 07:17 AM
Sopey15's Avatar
Sopey15
any suggestions?
Did you end up finding a fix for this? If you did, what was the problem?
Old Jul 13, 2021 | 12:34 PM
TVPostSound's Avatar
TVPostSound
It was most likely the fuel vent valve, common on Gen III
Old Jul 13, 2021 | 01:08 PM
Thielepr's Avatar
Thielepr
Yes indeed
Old Jul 13, 2021 | 03:46 PM
AirborneMini003's Avatar
AirborneMini003
Seems to be! Mine went out at 25,000 km. Was off warranty…seemed to be one of the culprits for my bad gas mileage. I was in pickup truck category for a few months before the CEL lit up.
Smells like another class action suit I’ll get an email about in a couple years.
Old Jul 13, 2021 | 07:16 PM
Sopey15's Avatar
Sopey15
Thanks for the replies you guys. I'm at 44,000 miles and 2 months out of warranty. Looks like I'll be buying a vent valve. Just wanted to check in case it was something like the pressure sensor.
Edit: Just updating to say that I replaced the vent valve and so far the check engine has been gone for a couple hundred miles. Fortunately it is super easy to replace.
Old Aug 19, 2021 | 02:57 PM
AutoCoarsen's Avatar
AutoCoarsen
I recently got a CEL on my 2017 Clubman S. Even got a ‘Reduced Power, but it’s OK to drive it’ type warning once. The morning the CEL and reduced power came up, there was a wild clicking from the engine right after I started the engine. It went away before I could track it down. Sounded like around the serpentine belt area - I only learned later the tank vent valve was nearby. I’m guessing that was the sound of the vent valve clicking uncontrollably. 🤷🏼‍♂️
Codes:
• P0446. Evaporative Emission Vent System Control Circuit.
• 191C02. Fuel Tank Ventilation System, 2nd Inlet Point. Malfunction.
• 195014. Tank Vent Valve, Pressure Sensor Venturi Nozzle, Signal: Permanently Stuck.
I’ve had a vent valve on order for a couple weeks, I’ll report back after install. Part number 13907614013
Related info. https://static.nhtsa.gov/odi/tsbs/20...76363-9999.pdf
Old Aug 20, 2021 | 07:16 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
Yep, had this done this week on my 2017 F54. Shop told me about the TSB and the fact that BMW had updated this part due to this problem......
Old Aug 20, 2021 | 07:34 AM
TVPostSound
Hey $3 is 3$!!
Old Aug 27, 2021 | 04:16 PM
AutoCoarsen
Got a new valve installed. Sure enough, you can see the internal valve broken, as described in the service bulletin. I looked at the valve a few weeks ago and it looked fine. Turns out if you shake the valve lightly you can see it’s loose in there.
Old valve made March 2016 and the new valve in December 2020. Same part number.
Super easy swap if you want to DIY. The “hardest” part is unplugging the electrical connection on the valve without breaking it 😅
Old Sep 14, 2021 | 02:19 PM
ebrown0104's Avatar
ebrown0104
I just replaced the valve on my 2016 F54 S. I had the P0446 and 191C02 codes. Cleared codes and the light was back on within 5 miles. Put the new valve on and have about 50 miles on it since then, no lights yet.
Old Sep 18, 2021 | 06:52 PM
EmedpaDHSc's Avatar
EmedpaDHSc
Ditto. 2017 Clubman S All 4. Still in the shop.
Old Jun 8, 2022 | 04:29 AM
Quentin's Avatar
Quentin
Ugh, we have this on my wife's 2017 Clubman S All4. The TSB listed above doesn't call out F54 (but it does call out the B46/48). Bought the new fuel filler cap, but the light came back on, so it is probably this purge valve.
Old Jun 23, 2022 | 07:42 AM
Quentin's Avatar
Quentin
Replaced the purge valve, reset the light, no issues since.
Old Oct 22, 2022 | 12:02 PM
Flyinace2000's Avatar
Flyinace2000
Should I bother going through the dealer for this or its it not covered under warranty? My Car is a 2017 Clubman S All4 with an early 2017 build date.
Found this SIM from MINI and its is basically the same as the BMW notice.SIM 13 01 20 2020-05-11 TANK VENTILATION AND MIXTURE CONTROL FAULTS STORED
IN THE DME
https://static.nhtsa.gov/odi/tsbs/20...76383-9999.pdf
Old Oct 24, 2022 | 05:04 AM
gearhead60's Avatar
gearhead60
Car out of warranty, you are on your own with this one.....
Old Oct 26, 2022 | 07:25 PM
Flyinace2000
Got the part at my 2nd closest BMW dealer for $140 (nearest dealer was $200???). Ordering online would have artbeen about $120 after shipping/tax.
Part was installed in about 5 minutes. Cleared the code and drove for about 15 miles and no new codes. Will keep an eye on it for a few days.
Old Oct 27, 2022 | 10:34 AM
TVPostSound
For those wishing to save a couple bux.
The Bosch branded is $36, shipping $5, same Bosch valve as the MINI and BMW branded boxes.
https://www.fcpeuro.com/products/min...ch-13907621174
$75 shipping included at ECS
https://www.ecstuning.com/b-bosch-pa...907621174~bos/
Old Dec 4, 2022 | 07:52 AM
gretna's Avatar
gretna
ur "a quick swap" still solved the problem a year later?
Old Dec 4, 2022 | 06:32 PM
AutoCoarsen
For me, yes.
Old Dec 9, 2022 | 05:55 PM
gretna's Avatar
gretna
our check engine light was critters seeking heat in the engine compartment, also then cut electrical wires to the fuel vent valve; and not cheap for the a full reading of the OBD-II Trouble Codes, and then wire repairs @ PAs top rated Mini Dealership.
Old Dec 12, 2022 | 10:24 AM
Been there, had wires chewed on my R52 twice. They chewed up the heat insulation also.
Old Dec 12, 2022 | 07:04 PM
WhatV8's Avatar
WhatV8
Does MINI/BMW use soy or plant based wire insulation? I know Ford switched to soy based insulation some years ago and apparently small critters find it quite attractive and delicious. Had a couple of my friends with F-150's end up with trashed engine harnesses within a couple weeks of each other this summer. The local dealership noted this happens regularly with the later models, since Ford switched material.
Old Dec 13, 2022 | 08:20 AM
Yep, they used this on some parts in the engine bay of the Gen 1 MINIs 2002+
Mike
