R56 Please Help
Old Jul 18, 2020 | 04:42 PM
hooverr77's Avatar
hooverr77
Please Help
Hello All!
I need help please... about a month ago I replaced the turbo feed line and the oil filter housing gaskets and since then I have been getting the P0597 with Limp mode. I have replaced the thermostat housing twice now thinking maybe one of them was bad and still getting the same code and limp mode and yes I bleed the system. Im out of ideas.. I have no idea what else it could be. I have read and everything points back to the thermostat housing. Please help.. and thank you!
Old Jul 21, 2020 | 09:44 PM
MiniToBe's Avatar
MiniToBe
it would help you a lot if you can read the live data of of the coolant temp and status of the thermostat. at least you can see if the temp is functioning properly and the thermostat is not stuck. Also, double check the pipes' routing in case you plugged some in the wrong inlet.
Old Jul 22, 2020 | 06:29 AM
hooverr77's Avatar
hooverr77
I use Torque to monitor and so far it seems normal like it was before all this started. and I did think about the pipes but like I said all this started after I changed out the turbo line oil feed and the oil filter housing gasket. But I will go thru everything again.
ricbow
Aug 20, 2023 03:40 PM
UserLain
Oct 4, 2020 11:15 PM
jglover
Aug 11, 2018 02:06 PM
danmx
Oct 2, 2010 05:32 PM
miniemee
Feb 11, 2010 06:04 PM
