R56 Catless downpipe question
Old Jul 12, 2020 | 11:00 AM
LDAWG48's Avatar
LDAWG48
I recently bought a catless downpipe for my 2011 Mini Cooper S and I’ve noticed a pretty steep power drop when it’s wet and I was wondering if this is harmful to the motor or if it’s like an intake where it just takes away a little power whenever it gets wet. I didn’t know if the downpipe would make the motor take on more water?
Old Jul 12, 2020 | 11:50 AM
oldbrokenwind's Avatar
oldbrokenwind
"--- when it's wet ---"? When what is wet, atmosphere, DP, motor exterior? "--- make the motor take on more water?" Coolant is a closed system, what's taking on more water?
Old Jul 12, 2020 | 11:52 AM
LDAWG48's Avatar
LDAWG48
Im just talking about like when it’s raining or going through a car wash. Will the catless downpipe take in more water and cause any issues? Bc I notice power loss whenever I’m in those situations.
Old Jul 12, 2020 | 12:24 PM
oldbrokenwind
DP should be "waterproof" --- external water is not supposed to be able to get into the DP, or anywhere else in the engine. Possibly your air filter housing has a plugged up drain hole. Or an exposed air filter is getting wet, inhibiting air flow. Just changing to a catless DP shouldn't cause a performance change in wet weather, but you should consider getting a stage 1 tune to compensate for the changes it will cause.
Old Jul 12, 2020 | 12:29 PM
LDAWG48's Avatar
LDAWG48
I haven’t had this problem whatsoever until I had the downpipe installed a few days ago. Could anything have been installed wrong or anything messed up during the installation that could cause weather to be an issue?
Old Jul 12, 2020 | 01:47 PM
oldbrokenwind
Maybe check for bare wires on the two DP O2 sensor connectors. Then check the air filter housing drain hole, it's not a difficult task. Otherwise, you're looking at a tune to compensate for different air density in the DP. Usually, when converting to catless, a code is thrown, indicating the ECU is seeing different quality air. Tuning can eliminate this difference. I hope you live in an area that doesn't require a catalytic converter. License renewal can be a problem.
Old Jul 12, 2020 | 01:49 PM
LDAWG48's Avatar
LDAWG48
Ya, I’m in Ohio so I’m not super concerned about not having the cat. There’s also nobody in Ohio that knows how to tune a Mini Cooper unfortunately and I’m trying to scrape up the funds to send my ECU to MarioKart lol
chav
Jun 7, 2017 10:51 PM
xSFx MISFIT
Nov 2, 2013 11:10 AM
dj.papazian
Apr 26, 2010 07:21 PM
Rovy
Apr 7, 2010 01:44 PM
