R50/53 replacement 22.5mm RSB bushings?
Old Jul 6, 2020 | 11:24 PM
Honeybadgers's Avatar
Honeybadgers
I got my R53 JCW having already been pretty extensively modified in 2016. I have a list of modifications but none mentioned the actual size of the rear sway bar, which has been clunking for about a year. I asked my tire guy to look at it while he was doing my rubber and he said the bushings for the RSB are toasted.
I got out the micrometer while doing my rear brake pads today and measured it at 22.5mm. I cannot for the life of me find a replacement RSB bushing in that size.
Are there any out there? Can I coax a 22mm bushing to fit? Because I can find those for days.
Old Jul 8, 2020 | 10:28 PM
Honeybadgers
I ordered some 22mm from M7, they said the 22mm can be coaxed to fit the 22.5. I'll report back if they don't work (otherwise just assume that they fit)
Old Jul 8, 2020 | 11:59 PM
CFGP's Avatar
CFGP
I just used Google with this search term.: Rear Anti-Roll Bar for the MINI, 22.5mm bushings and found several images for 22.5mm bushings. You might try Detroit Tuned: https://www.detroittuned.com/powerfl...-bar-bushings/
Old Jul 9, 2020 | 04:33 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Send us a photo and we can tell you what bar you have. if it is aftermarket, its 22 or 25 mm no one made a 22.5 mm bar.
Chad
DT
office@detroittuned.com
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jul 9, 2020 | 08:09 PM
colinmini's Avatar
colinmini
https://www.summitracing.com/parts/ens-9-5158r
Summit Racing Equipment have them in stock. $22
Old Jul 12, 2020 | 08:45 PM
Honeybadgers
I figured out what they were, buried in the car's service history (which is more than an inch thick), a handwritten "MM rear sway bar installed" on a service record.
Googled it, minimadness' 22mm RSB matches it perfectly, down to the weirdly shaped bushing clamp they had. So it is a "22mm" bar, they just made it about 22.4mm in diameter according to a calibrated micrometer.
Got the 22mm bushings with angled zerk fittings so no more need to remove/replace for grease. Hopefully they fit the minimadness bar.
Old Jul 13, 2020 | 11:23 PM
Honeybadgers
Bushings are on, swapping them was literally a twenty minute job start to finish, and that included taking out and putting away all my tools.
The dealership refused to do this job and said that it was a huge headache to do. F**king liars. It was four bolts and four small screws.
Rear end clunk is gone. I wish I did this a long time ago, I just had been convinced by the dealer it was a huge pain in the ***.
33EJB
Apr 29, 2016 05:19 PM
Quitman Rhinehardt
Suspension
Dec 9, 2013 01:18 PM
Jollynut
Suspension
14
Aug 20, 2012 09:26 AM
lovethecorners
Suspension
Apr 1, 2010 11:12 AM
custard
Suspension
Feb 18, 2009 01:26 PM
