F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Aftermarket rear fog light F54
Old Jul 4, 2020 | 10:49 AM
EmedpaDHSc's Avatar
EmedpaDHSc
Question Aftermarket rear fog light F54
I am the 2nd owner of a 2017 clubman S all 4. The original owner did not opt for the rear fog light. I want to add one. The dealer said it costs thousands of dollars to do so.
any aftermarket options that won't break the bank?
Thanks-
Old Jul 4, 2020 | 03:30 PM
MVPeters's Avatar
MVPeters
Find another dealer!
I believe you have the lights or at least the housings, already installed. All you should need is the right switch & the $$$ programming.
The $$$dealer charge is probably close to what that option would have originally cost from the factory.
Old Jul 4, 2020 | 04:08 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Many have opted to just code the rear fogs as additional brake lights. You can check the older F56 thread https://www.northamericanmotoring.co...pert-mode.html
Old Jul 4, 2020 | 08:25 PM
EmedpaDHSc's Avatar
EmedpaDHSc
Thumbs up
Thanks! will do.
Old Nov 20, 2023 | 09:45 AM
EmedpaDHSc's Avatar
EmedpaDHSc
Cool rear fog revisited
I bought the switch from ECS tuning that includes both fog lights https://www.ecstuning.com/b-genuine-...t/61315a25471/
and found an independent shop to install it and code the lights with Bimmercode. Whole deal should be around $400, including the part. I drive in the fog a lot in the PNW, so am thinking of this as a safety improvement, not a performance upgrade. Easier to sell myself on the price. Will report back after it is done.
Old Nov 20, 2023 | 01:59 PM
Yep those rear fogs work. I have them stock on my range rover and i have them on my R58 and my old R52.
Old Jan 4, 2024 | 05:24 PM
EmedpaDHSc's Avatar
EmedpaDHSc
They work!
I bought the switch from ECS for around $200 and my local independent mini shop installed it and did the coding for around $200, so functional rear fog lights just like European stock minis for $400. Very pleased.
apenough
Oct 7, 2019 06:47 PM
Otra
Oct 23, 2012 01:53 PM
El_Jefe
54
Sep 2, 2006 11:26 AM
markvibari
South East - Florida
Jun 18, 2003 12:20 PM
Pebbles
Mar 1, 2003 04:20 PM
