R50/53 New Clutch, lost power to wheels
Hi guys - So I just got my 05 R53 back from my mechanic on Tuesday after a new Valeo clutch install, as well as two new axles (DTA as recommended by ModMINI) and a few other things.
The car drove great for 4 days, but yesterday as I shifted from 2nd to 3rd, gas pedal went back down and the engine revved... that was it. I coasted into a parking lot and tried to eyeball the axles, all looked ok from what I could tell.
I'm able to press the clutch pedal in and it feels fairly similar to normal operation. I can shift into and out of all gears without the clutch pressed in (although a bit harder for some gears). My initial thought was clutch fork or pressure plate (uggh) but when the car was getting loaded onto the flatbed there was a trail of clear (hydraulic?) fluid and a subsequent pool was left after the mile long trip to the shop.
My mechanic is out of town until after the 4th so I thought I'd hop on here and have my hopes crushed - Does this sound like a stuck or busted slave cylinder to anyone? If not why the leaking fluid?
Any thoughts or suggestions would be appreciated and wish me luck!
D
D
Could be brake fluid (from the slave cylinder). Also could be transmission fluid if the DTA axle popped out. This happened after I put DTA axles in my car, the driver side came loose after about 100 miles and leaked a bit of fluid until we took it out and put the OE circlip back in to keep it held in tightly. I check it whenever I'm under the car but 5k miles later and all is tight.
Prinler
Aug 17, 2017 10:03 PM
R50/53 issues after clutch install
Keisukesan808
Jun 12, 2016 07:17 AM
E_Swift
Nov 27, 2013 07:26 AM
Drivetrain Help!!! Clutch won't fully disengage
soccerbummer1104
Mar 24, 2012 03:24 PM
