I recently picked up a set of used aero side skirts and the mounting panels but no fasteners. I couldn't find these on RealOEM to find the fasteners needed to install. If you know where to find on Real OEM let me know. If you have a list of the fasteners needed let me know also.
I assume I can use the fasteners that hold the bottom of the standard skirts to fasten the mounting panels? Perhaps the other fasteners that hold the standard skirts on also? Assuming none of them break. I'd just need the fasteners that hold the aero skirt to the mounting panels. Would these be more of number 4?
TIA
Also, I have an R52 (convertible) with the braces underneath. Will I need to carve away some of the aero skirt or the mounting panels to get around these?
Anyone have a good list of the fasteners (Push pins, rivets, nuts, clips etc) that are needed to mount the Aero skirts, and skirt adapters to the car when changing out from standard to aero skirts... without re-using any old fasteners??
I've looked on Real OEM... and cant find a thing on this.
Those type of fasteners are cheaply available by the big bag from Chinatown of course, easy to find, and the OE parts are likely sourced from there too I'd wildly guess altho the quality control may be upped a notch, but I don't really know.
Wish that the R50/R52/R53 instructions were laid out more like this one for R57:
Yep, just pop the oem part number into our site, sometimes dependent on the fastener we have aftermarket solutions that can save $$$, ours are cross ref off the OEM part design and number.
Looks like I'll need to also purchase some VHB double sided mounting tape for the attachment of the top surface to the body per the instructions you linked
