Radio swap out
Old May 25, 2020 | 12:21 PM
Rewind's Avatar
Rewind
Radio swap out
I have a 2007 R56 with radio and CD player that the screen doesn't work on. I purchased the same type radio from another 2007 R56 to swap out with. Other than just swapping the radios is there anything else I will need to do?
Old May 25, 2020 | 09:02 PM
giorgos's Avatar
giorgos
According to the instructions here:
https://www.newtis.info/tisv2/a/en/r...d-dvd-changer/
programming/coding is required. But maybe someone who has actually done this has a workaround (I would doubt there is one, though). Also: there is quite some information about it here on the forum. A quick search should yield threads documenting such a replacement.
Old May 26, 2020 | 06:58 AM
MiniToBe's Avatar
MiniToBe
it should be plug and play.
programming and coding is step needed only if you want to mach the VIN. other than that, there is no downside.
mildensteve
Aug 16, 2020 08:53 PM
Pootietang
Feb 24, 2018 01:20 PM
vdan
Aug 3, 2010 10:20 PM
Prost
Asia
May 22, 2008 12:38 PM
lestat2345
Europe
Mar 19, 2007 01:14 PM
