Suspension End link pre-load?
Old Dec 20, 2004 | 04:56 PM
asodestrom's Avatar
asodestrom
End link pre-load?
"These rear swaybar drop links include heim joint ends that are adjustable to set preload"
What does pre-load on a swaybar actually do? A sway bar moves freely when not loaded and doesn't really work until cornering. So it seems to me that you would need to set your end links at different lengths to pre-load the bar. I can see how this would work if you were running on an oval track, turning only one direction, but what does it do for daily driving, or on a road course?
Am I missing something?
Old Dec 20, 2004 | 06:40 PM
kenchan's Avatar
kenchan
I was able to level the rear end of my Protege5 running eibachs when I had adjustable endlinks on that car... regardless, i sold the car.
Old Dec 20, 2004 | 10:55 PM
SpiderX's Avatar
SpiderX
I just had my car corner balanced today and they got it very close to 50/50 cross corner weight. They said to get it any better that I should get end links for the sway bar. I hope I am relaying this right.
Old Dec 21, 2004 | 04:13 AM
jlm's Avatar
jlm
when you corner weight, the sway bars should be disconnected. after setting the weight by adjusting the coilovers, you then hook up the swaybar links. If one of the links is adjustable, you can do it without putting any side to side torque into the suspension. (that would throw off the corner weight you just set.)
Old Dec 22, 2004 | 11:41 AM
kenchan's Avatar
kenchan
Yah, this is why I get a little nervous when I see swaybars arriving in
beat-up boxes as it could be stress-bent which will throw off the leveling.
Stillen does a great job boxing up their swaybar kits for their lineup.
very nice job. :smile:
Old Dec 22, 2004 | 12:22 PM
asodestrom's Avatar
asodestrom
So you are suggesting that an adjustable end link is more useful in eliminating pre-load than adding it? That makes sense to me.
Old Dec 22, 2004 | 03:52 PM
jlm's Avatar
jlm
if you are circle trackin' no; otherwise, yes.
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
Sep 3, 2015 10:45 AM
Sep 3, 2015 10:29 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
