Reset Service Interval Display
Old May 15, 2020 | 08:45 AM
mayagrafix's Avatar
mayagrafix
I recently acquired a 2003 R50 Hatchback with 134,000 Km (80k miles) and I had some maintenance done by my trusted mechanic (brakes, tune-up, oil change, shocks). Now I would like to reset the Service Interval Display back to zero. Do I need an OBD2 scanner or another device to do this? currently, it shows "5550 Oil Change" when I turn the key to power (position 2)
Thanks for your help
Old May 15, 2020 | 10:49 AM
Capt_bj's Avatar
Capt_bj
1. Press and HOLD the trip reset button
2. Insert key and turn to position 1
3. Watch for display to change to RESET
4. release trip button, then press again and HOLD
5. watch for RESET to flash
6. RELEASE trip button and then press briefly and release (only once)
7. Service interval should resent to a number (which can vary. it won't go to zero .. it is a countdown ... if it says 5500 now that means the computer thinks you have 5500 'til next tracked service item ... usually oil)
my 02 was very persnickety about the timing of this sequence and it usually took about 3 tries for me to get it right ... but it DID work ... eventually.
radaghast
Aug 11, 2017 07:46 PM
devinw
May 11, 2009 05:03 PM
Cowtown Mini
Mar 7, 2009 09:37 AM
minimotoman
Jul 18, 2007 08:15 AM
ED955S
May 27, 2007 05:32 PM
