R50/53 Need Help innovative wideband A/F gauge wiring
Hello. Anyone have a link or know where to splice the white wire to? It says headlights. ( for night time dimming )
all the other links i saw didnt mention this.
also. The yellow wire to the ecu for logging. Since I’m using the bytetronik device i might not need this to log.
a pic and wire diagram would be so helpful. Thank You guys
You can connect the white wire of AFR gauge to Body computer,is located at the base of the A Pillar on the right hand side of the vehicle. It utilizes four (4)connections: one 20-pin connection and three (3) 54-pin connections.Look for grey/violet wire(park left side light) or grey yellow wire(park right side).
Right hand side? Glove compartment area?
So They will djm when i have my park lights on before it switches to headlights.
i do drive with the park li s on since i don’t have daytime running lights. I’ve replaced my front signal/parks guts to LED to serve as my DRL.
you talking about the BCM https://cdn4.pelicanparts.com/techar...mall/Pic29.JPG
https://cdn4.pelicanparts.com/techar...mall/Pic30.JPG
In order for the MINIPort to log AFR from the Innovate, you'll need the Innovate Serial Patch cable (#3812) for the MTX-L and MTX-Plus:
https://www.amazon.com/Innovate-Moto...9422844&sr=8-1
