spark plug multipliers
Old May 10, 2020 | 06:42 AM
genik's Avatar
genik
Is it possible -without a scan- to know if one of my spark plug multipliers needs to be changed?
Old May 10, 2020 | 08:13 AM
Jason Cornelius's Avatar
Jason Cornelius
It is way easier with a scan tool, you can move the coil packs around and your misfire code, if bad, should change cylinders.
Old May 10, 2020 | 08:30 AM
genik's Avatar
genik
what do u mean by moving around the coil packs?
Old May 10, 2020 | 08:33 AM
Jason Cornelius
If you have a misfire on say cylinder 1, if you swapped out coil pack 1 with 2 and the misfire moves from 1 to 2, then you know it’s that coil pack.
Old May 10, 2020 | 09:39 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Sorry, but I'm not familiar with the term "spark plug multipliers"? What is this?
Old May 10, 2020 | 11:58 AM
giorgos's Avatar
giorgos
He means coil packs, the term got lost in translation.
Old May 10, 2020 | 03:48 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Ah, thanks.
Old May 10, 2020 | 04:50 PM
genik's Avatar
genik
Originally Posted by njaremka
Ah, thanks.
sorry about the misunderstanding... it was my fault
Old May 11, 2020 | 03:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Not at all! I asked out of curiosity.
And, back to your original question... if you are getting a rough idle, or any kind of misfire, your coils and plugs should probably be replaced. Also, best to replace them as a set, rather than just one or two at a time. I would also consider the coils and plugs to be maintenance items to be replaced every 40-50k miles.
Old May 11, 2020 | 09:34 AM
Jay Bacon's Avatar
Jay Bacon
Coils are super simple, like the other guy said, swap your coils and rescan your codes. (most parts stores will have a scanner you can use in their parking lot) once you confirm its a coil, replace said coil.
I have often replaced just one coil at a time as they go bad, sure its recommended to do all 4 and plugs at the same time, but never had an issue with doing one at a time... and I just started doing them on mine. (original owner never did them) and I have 250k km on my original spark plugs (swapped out now since i did timing chain and figured why not) but coils, ive been doing em 1 at a time as they fail. (2 outta 4 so far, other 2 are going strong).
Sam Smith
Jun 6, 2019 11:16 AM
Moto44
May 1, 2013 01:10 PM
blutnk007
May 18, 2008 02:34 PM
DrkSilver163
Electrical
Apr 4, 2005 07:49 PM
