R56 Brakes and clutch
Old Apr 30, 2020 | 04:17 PM
ghaut's Avatar
ghaut
Brakes and clutch
Do the brakes and clutch use the same reservoir?
share the same fluid?
Old Apr 30, 2020 | 05:26 PM
Jason Cornelius's Avatar
Jason Cornelius
Correction they are.
Old Apr 30, 2020 | 05:29 PM
thebombardier's Avatar
thebombardier
Yes, brake fluid and clutch hydraulic fluid are the same and are fed from the same reservoir.
Old Apr 30, 2020 | 05:30 PM
Jason Cornelius
really?
Old Apr 30, 2020 | 05:31 PM
thebombardier
Originally Posted by Jason Cornelius
really?
Yes.
https://www.northamericanmotoring.co...tructions.html
Old Apr 30, 2020 | 05:35 PM
Jason Cornelius
Thanks, so here is my million dollar ? Because I’m getting ready to swap brake fluid. Am I going to have to bleed this too?
Old Apr 30, 2020 | 05:37 PM
thebombardier
Wouldn't be a bad idea. All the fluid is going to age the same. But unless you're specifically having issues related to engaging and disengaging the clutch I wouldn't really worry. The brake hydraulics and clutch hydraulics are pretty isolated from one another aside from sharing a reservoir.
Old Apr 30, 2020 | 05:44 PM
Jason Cornelius
I just had clutch done 4000 miles ago and there are no issues there, just changing out fluids I didn’t put in there and brakes are the last one.
Old May 1, 2020 | 02:20 PM
ghaut's Avatar
ghaut
I should be able to change brake fluid and not affect the clutch?
Old May 1, 2020 | 02:26 PM
thebombardier
Yes. Just make sure you don't run the fluid below the stem that runs down into the clutch line.
Old May 6, 2020 | 07:21 PM
joedotmac's Avatar
joedotmac
And going below the feed lines where they are plumed in the reservoir is easy to do if not using a brake bleeder wet method.
Old May 7, 2020 | 08:14 PM
ghaut's Avatar
ghaut
Thanks everyone for the info that was helpful 😊.
imaslowdriver
Mar 19, 2020 12:42 PM
Colin Schlagel
May 17, 2018 12:05 PM
jeffl
Oct 8, 2016 03:57 PM
101101
Aug 5, 2007 01:13 PM
