R50/53 Mini is down for the count
Old Apr 29, 2020 | 10:35 AM
minigrey06's Avatar
minigrey06
hey guys,
My 06 has been down for the count for the past 9 months.months taken it to the shop for an oil change and 2 miles later as I was pulling into my street, heard a sort of clattering almost chain like noice...no warning light. No temp change, no funny smells...and the car stalled...I literally coasted the rest of the 100 ft to the house and pulled it into the garage. There she sat all this time... figuring out what to do now...could it have been a timing chain tensioner?? If so. Did I do catastrophic engine damage? It wouldn't even turn over after that, just click click when I hit the ignition.
Car is mint condition w 165k miles I really enjoy it, but I don't think I want to drop in a new engine... prior to this the car had been bullet proof with the exception of having to change oil filter housing assembly (with built in cooler) since it started making a weird chain noise...and oil light would come one...replaced that part and then less than a year it failed again got another under warranty and then few months later this issue described above.
thoughts? I was thinking of selling also..as I'm scared of it becoming a rabbit hole $$$...
Old Apr 29, 2020 | 10:41 AM
minigrey06's Avatar
minigrey06
Old Apr 29, 2020 | 01:28 PM
SupeR53's Avatar
SupeR53
Waiting was not a good idea, if they mangled something while changing ht oil (or failed to put any back in) you would have had some recourse, Nine months later all bets are off. Did you check the oil after it stopped? Have you looked at the front of the engine to see if the drive belt is intact? You're not giving anyone much to go on.
Old Apr 29, 2020 | 03:17 PM
minigrey06's Avatar
minigrey06
It was nothing the shop did. Been going there for 4 years and it was only an oil change, there's no way the could have damaged my car - oil is perfect and at the right level. Drive belt is intact.. there's no compression. Thinking maybe chain tensioner failed and chain popped off prob threw a valve... Engine will be about 3K total for a sub 100k used one. So I'll prob just sell the car for as close to 2k as I can.
Old Apr 30, 2020 | 04:42 AM
David Baker's Avatar
David Baker
Unless you've done other internal engine modifications you shouldn't have any valve to piston contact. Could the timing chain guide or tensioner failed, absolutely. If you pop the rocker cover off, you can look at the chain and see if there is any tension in it before you get to digging too deep. If the guides broke, you won't see that without removing them or pulling the oil pan and fishing out the parts.
Old Apr 30, 2020 | 04:27 PM
minigrey06's Avatar
minigrey06
Thanks for the input David. It's all good, sold it this AM for 2 grand.. I'm satisfied w that outcome.
cheers guys!!
crdouger
Dec 26, 2018 01:52 PM
ives
Dec 21, 2014 12:46 PM
jkling17
Apr 2, 2014 12:44 AM
bharms
Feb 22, 2014 09:10 AM
daflake
Mar 23, 2012 05:24 AM
