R52 rear side window off track?
OK, so the damn top wouldn't close again. got almost up to where the arms were just about to lock at the top of the A pillars , then it quit. All the windows would still function up and down, but when the rear sid windows got almost fully up, the left rear window Popped and now won't move at all- all the rest of the windows will close and the top finally closed after sitting for 10 minutes.
How tough is it to get to the mechanism for the rear side windows?
could the top failing to operate normally be from the top motor overheating? The red light quits working when the top stops. I had all the sensors replaced and the problem is so intermittent they can't find the answer/cause.
Heres the thread showing the "fixed" plastic guide ...https://www.northamericanmotoring.co...r-replace.html
+1 ^^ Yep, you can adjust the window if its off and not off the track
https://www.northamericanmotoring.co...ndow-leak.html
R50/53 Roll down the back window?
XXLil MickXX
Jul 15, 2011 04:12 AM
R50/53 rear window dimensions
onetwelve-112
Jul 16, 2003 08:41 AM
