R50/53 Body Control Module question
Old Apr 26, 2020 | 12:08 AM
Omar Salem's Avatar
Omar Salem
Hello,
I have a mini cooper s 2006. The car was parked in an area where a flood happened and some water got into the car from the passenger side. Thank god there was no damage except that the passenger window wouldn't work.
I changed the window regulator and still didn't work, I was told maybe the problem is in the switch so I changed it and still the same problem going, the window can go up but won't go down. Then I found out that the problem a 100% is from the body control module and it made sense because it's located exactly where there was water from the flood.
Now I want to replace the BCM but I was wondering if I need to go to the car dealership to reprogram it, does anyone have an idea? because I was planning on getting a used BCM. please help if anyone knows or have an experience in that. Thank you
Old Apr 26, 2020 | 12:07 PM
adriancl's Avatar
adriancl
You can buy an used one, but must have same part number.No need to pair, is plug and play.If intend to avoid a dealer visit to reprogram in case the donor car have other specs than yours(presence of xenon, sun roof, fog lights, different AC type)you can use INPA cable and NCSExpert sw to recode BCM to your car specs.A new one is around 500$.Used one is cheap.
Old Apr 26, 2020 | 01:58 PM
Omar Salem's Avatar
Omar Salem
Thank you for your answer. I found some few used ones online with the same part number. If I need to reprogram the BCM, you think a local mechanic should be able to do it for me? I want to avoid going to the dealer.
thevin70
Apr 18, 2012 12:59 AM
airics
May 4, 2010 06:50 PM
saturn5rocket
Jun 6, 2008 09:29 PM
Eric B
Nov 1, 2006 04:06 PM
redrover
Apr 9, 2004 11:02 AM
