I am working on my friend's 2007 R56s which has a no start condition. while we're figuring the issue with his N14, I decided to drop my N18 in his car like what I've done on the clubman In this thread
That's looking pretty good. How do the electronics & wiring match up with the engine change? Does the car need to be told it's now running an N18? In addition to the dual vanos, what else has been redesigned/improved from the N14?
The engine harness and ECU are N18 specific. the only change will be in the body side of the ECU plug; last time I did it, it was 2 or 3 wires. I am still going to use the CAS and keyfob matched to the ECU until I figure a way to marry the donor ECU to the original CAS.
The PCV design is also improved. because of the dual vanos, the pistons and the head have a different design than the N14. it also has slightly more power and it is more quite than the N14.
