R55 rear barn doors
Old Apr 13, 2020 | 09:19 AM
CountryMouse's Avatar
CountryMouse
R55 rear barn doors
I have a problem with my 08 s clubman that I haven't been able to sort out. I've been getting a rear door ajar warning that dings whenever I come to a stop and start again (red lights, stop signs, etc) and cargo/rear puddle lights no longer switch on when the barn doors are opened. the problem began shortly after I replaced a faulty right barn door latch. The doors latch and work and I've tried adjusting the latch but the dings continue.I'm more concerned with the door as I suspect the the dead lights are a symptom of the car not being able to tell when the doors are shut. Is there a sensor or a fuse that needs replacement? Or something to reset? Also the rear wipers, washers, and defroster aren't working. But the door latches and works from both the fob and the door handle.
Old Apr 14, 2020 | 06:31 AM
Something sounds like I would check the rear wiring harness it the door with all those things not working, sounds like its chaffed.
Old Apr 14, 2020 | 06:46 AM
CountryMouse
I've ran the length of the wiring harness and found nothing continuity from end to end and megged out the insulation no holes. I believe it may be in the frm module, no output to connectors pin outs.
Old Jun 27, 2021 | 07:46 AM
Paradave's Avatar
Paradave
solved?
Hi countrymouse!
I have exactly the same issue, did you solve it?
Old Jun 27, 2021 | 09:15 AM
Michael Gluth's Avatar
Michael Gluth
Originally Posted by Paradave
Hi countrymouse!
Yes I did... it was the sensor inside the door latch. Have to replace the whole electric door latch assembly. The passenger side one. Just make.sure you get the correct one. Both latches look the same but one has the needed contacts
inside.
Old Jun 27, 2021 | 09:24 AM
Paradave's Avatar
Paradave
inside.
Ah, thankyou so much for the reply!
when you say passenger side, is yours also left hand drive? i.e the latch in the door and not in the boot well?
Old Nov 3, 2023 | 09:41 AM
Sagviki's Avatar
Sagviki
inside.
Yes, thank you. I just checked both the old one, and the new one, and they completely identical on the outside but I looked inside lock system and they are a little bit different. In the old one there is a small metal piece which turned out to be the sensor! When I plugged back the old one all the rear lights light up again, and as I pushed that sensor with a thin pin the light shut down. So it turned out that is what causing the problem, my new lock doesn't contain that sensor...
I think i have to buy a new one...
2014 MC
R60/R61 Stock Problems/Issues
Jan 14, 2020 09:49 AM
rbaker66
F54 :: Clubman Talk (2015+)
Jun 23, 2019 06:49 AM
RockyRoad
R55 :: Clubman Talk (2008+)
Oct 25, 2017 07:20 AM
Xeraux
Nov 9, 2011 03:11 PM
MDriver
Apr 18, 2008 09:34 PM
