R50/53 Extended lug info needed
Old Apr 9, 2020 | 09:00 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I have been trying to find the correct size lugs for my r53 and have found literally 3 different listings of the size . I need stock size diameter but need alittle extra length as I'm going to be running 5mm spacers . Are these ones I found the correct ones ??? If not what , what lugs would i need that are about an extra 5mm long..?
https://www.ebay.com/itm/NEW-12x1-5-silver-Radius-Seat-wheel-lug-20-1-pcs-shank-33-mm-for-Mercedes/164088539810?hash=item2634706aa2:g:YpsAAOSwW1BeTQ5 V&fits=Year%3A2004%7CMake%3AMini%7CModel%3ACooper& _nkw=12x1.5+33mm
Old Apr 9, 2020 | 09:05 AM
Da_Ghost's Avatar
Da_Ghost
You could also simplify your life by swapping to studs, most kits are long enough to run a spacer too. Bought mine from Outmotoring 8 years ago, I'm not running spacers, so you'd need to confirm with someone who does.
Old Apr 9, 2020 | 09:27 AM
MiniManAdam
Community Builder
I looked at them but I like the cleaner look of the stock style lugs.
Old Apr 9, 2020 | 10:14 AM
cristo's Avatar
cristo
Alliance Member
Yes, 28mm stock + 5 mm spacer = 33 mm.
Old Apr 9, 2020 | 10:36 AM
MiniManAdam
Community Builder
so the ones I have a link to would be the correct width then ? If so I have to order those asap
Old Apr 9, 2020 | 11:44 AM
veedubpat's Avatar
veedubpat
Make sure you get the right seat style as well. OEM Mini wheels, and many aftermarket wheels, use cone seats. I believe those Mercedes lugs will be ball seat, same as VW. Not cross-compatible.
Edit: https://www.ecstuning.com/b-ecs-part...c17a35-znnitt/
35mm long ones will work. 2mm out the back of the hub won't interfere with anything.
Old Apr 9, 2020 | 11:50 AM
MiniManAdam
Community Builder
Ooooooo. Good thing you pointed that out to me , I better check what kind of lugs fit into these new rims ..
Thx for pointing that out.
Old Apr 9, 2020 | 03:00 PM
RB-MINI's Avatar
RB-MINI
My wheels had the same seat type, but I wasn’t sure if the lug hole depths were the same for all wheels so I measured how much the stock bolt stuck out of the back on the stock wheels and aftermarket wheels to see if there was a difference. Then I looked for lug bolts so the aftermarket behind the wheel measurement equaled stock plus spacer.
wakemini21
Oct 4, 2012 03:15 PM
dooky
Tires, Wheels, & Brakes
Feb 10, 2010 07:08 PM
roofaS
Apr 12, 2009 03:17 AM
pastadog
Suspension
Feb 21, 2006 10:20 AM
