R55 B1S1 oxygen sensor issues.
I got a code for my wifes 2010 justa (199000 miles, first replacment!) for the B1S1 oxygen sensor. I ordered one and installed it.
Code gone... Next day CEL comes back on. I grab my dongle and its now P0420! I replaced the cat/manifold about 40k ago.
I head to graphing in torque, and the sensor isnt reading at all. Im assuming that its that way until up to temp, so i go on a 20 min drive, still no voltage, its using the assumed maps.
I head to newtis.info and check wiring diagrams, as there are 6 wires, and the original code was for "oxygen sensor pump failure(??)". The wiring diagram does not explain what wire does what. There are 2 yellow, 2 white, one orange and one black.
Can someone help me out with wire assignments so i can check voltages?
I would like to know if i have a bad out of the box sensor, or wiring issue. Or is there a fuse for the oxygen sensors? B1S2 varies up and down with normal graphed voltages.
Id love to hit 300k with it. My 04 x3 is at 202k
rauls4
Oct 16, 2019 02:53 PM
WABFZ1
Sep 25, 2018 12:00 PM
