R50/53 Garage remote button stopped working
Old Apr 2, 2020 | 08:05 PM
ladsjohn's Avatar
ladsjohn
The garage remote buttons on my auto-dimming rearview mirror have stopped working. The auto dimming feature still works so it's getting power to the mirror.
I've tried removing and reconnecting the wiring harness to the mirror to no effect. It doesn't look like the mirror comes apart to inspect the internals.
I had 2 buttons programmed to my 2 garage doors. Neither of them now work
The little led light does not illuminate when I press any button, nor when I hold down any button.
This is a factory option. I did not retrofit it.
Short of sourcing a used mirror - anyone have any ideas how to troubleshoot it further?
Old Apr 2, 2020 | 10:15 PM
Katgirl's Avatar
Katgirl
Sounds like it needs a battery, perhaps?
Old Apr 3, 2020 | 02:37 AM
deepgrey's Avatar
deepgrey
It’s hardwired.
There was a thread recently regarding flaky keyless entry where someone popped the mirror apart and found corrosion on the PCB inside, so they do come apart. Or at least the manual dip mirrors do. Apparently the corrosion issue isn’t unheard of. Perhaps you have a similar issue with the homelink module.
I don’t have a ton of experience with that system though. I retrofitted the autodim mirror with homelink to my car a couple of years ago, but I rarely use homelink portion because we have a carport. I don’t know if it can forget the door code, but it seems like the light should come on regardless.
Old May 5, 2020 | 09:57 AM
ladsjohn's Avatar
ladsjohn
Just to loop back on this. The R53 auto dimming mirror does indeed come apart. I pried it open using trim panel tools.
Disassembled R53 auto dimming mirror
The homelink module (left of centre) appears to be in good shape. No loose connections, no loose solder or any corrosion on the PCB.
I ended up going with a replacement mirror from a scrapyard as I couldn't see anyway to repair or replace the homelink module.
Sodd
MINI5280
Oct 16, 2013 09:02 AM
11mcsaz
Nov 8, 2012 10:02 AM
Steve S
R55 :: Clubman Talk (2008+)
Feb 9, 2012 01:00 PM
emans
Mar 4, 2010 09:13 AM
MileHiMini
R57 :: Cabrio Talk (2009+)
Sep 23, 2009 07:19 PM
