R56 Oil Leak Cause?
Old Mar 22, 2020 | 10:07 AM
prmspen's Avatar
prmspen
Oil Leak Cause?
My 2011 JCW is leaking oil from under the front passenger side. Pretty much right under the dipstick (maybe a little behind it). Oil level doesn't seem to be dropping at all, and it's not a huge leak (couple of drops per night). Any ideas on the source?
Old Mar 22, 2020 | 10:34 AM
bugeye1031's Avatar
bugeye1031
Moderator
Probably crank seal or oil pan gasket.
Old Mar 22, 2020 | 11:22 AM
seandallen's Avatar
seandallen
+1 on crank seal or oil pan gasket
Old Mar 22, 2020 | 12:09 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Front crank seal would be my first guess on that side
https://www.waymotorworks.com/front-...18-engine.html
Old Mar 22, 2020 | 12:38 PM
Lancaster's Avatar
Lancaster
In addition to the crank seal and pan gasket is the tensioner bolt. When it backs out, oil flows down the block behind the intake manifold and disguises itself as a pan gasket leak. We learned this the hard way
Let us know if you want to try to DIY. It is very straightforward yet expensive to pay someone else for due to the "book time." Soon DIYers will learn how easy it is to work on the r56 when you get a few things down.
Old Mar 23, 2020 | 09:38 AM
prmspen's Avatar
prmspen
Definitely interested in a DIY check on the tensioner bolt. Please share.
Old Mar 25, 2020 | 06:51 AM
Lancaster's Avatar
Lancaster
Go to NEWTIS. Enter your Vin. Locate Tesioner bolt. I have an N12 engine and it is located behind the PCV outlet to the manifold on the head side of the intake. Tighten to spec.
Old Mar 25, 2020 | 06:53 AM
Lancaster's Avatar
Lancaster
Also, look to see if this part has been updated for your engine. My '08 had a new updated one. Replace if needed. Simply turn out with a crawfoot wrench in my case and replace. I may have had to loosen the intake but do not remember. For me that was just 5 10mm nuts.
puwit321
Mar 28, 2018 02:23 PM
Sleepie
R60/R61 Stock Problems/Issues
Nov 26, 2014 08:19 PM
Shoe Coupe
Jan 21, 2013 11:47 PM
Myke@RPI
Mar 19, 2010 08:07 PM
