R50/53 Low power and low boost , need advise
My car as of today I went to start it and I heard the belt squeal on start up and it continued to squeal loud for about 5min , then it only squeaks now for a few seconds on start up but when I go wot it only makes 5lbs of boost and as I apply anything more than half throttle I hear a bad kinda scratchy noise front the engine that's very hard to describe. My car has a 15% pulley so I dont know if it even has the correct belt as I've only ever seen 11lb of boost and once it got past 9psi it made a kinda loud squeal that I'm sure was the belt and I'm willing to bet it had been slipping since I've had the car . Could I be correct in the assumption my belt or tensioner or both are bad ? I have no codes and it idles fine with no odd noises and I couldn't see the tensioner bounce at idle at all or when revved . It only makes that bad noise when giving a decent amount of throttle .
also I think I have the alta tensioner thingy , is the alta one a hexagonal shape that has nuts on either side to I think adjust it ???? If so ,could it just need adjustment ? If so can someone link a how to and I could try that 1st.
What length belt should I use? I keep finding conflicting part #s as I try and run the search ..
15% pulley n stock crank
1379mm and a 4rib , is that correct . Then I could run to a local parts store and hopefully they have one on shelf.
and to adjust the alta tensioner , to tighten the tension . Do I loosen the 2 retaining nuts and rotate the middle piece towards me or away from me? So rotate it towards engine or away ? I would assume rotating it away/ towards me would expand it and make the tension . But lol idk.
Throw the ALTA tensioner in the garbage...even if you have the right size belt it stops the tensioner spring from working properly. It is a fixed length...factory is a gas charged strut for a reason...it allows the pulley to move with spring pressure and apply proper tension to the belt.
6 rib belt
6 rib belt
6 rib belt
6 rib belt
Check your crankshaft damper also. If it's stock, the core could have separated and the pulley is not spinning at the proper speed. As a comparison, I've seen 14.5psi of boost on my S at less than full throttle.
Check your crankshafter damper also. If it's stock, it's possible that the rubber core has separated from the pulley. As a comparison, my S has registered 14.5psi boost at less than full throttle.
I believe it is my crank now...see my new post.
I adjusted the tensioner and now i MAKE 15LB OF BOOST !!!!
lol I test drove it N omg those few lbs made a huge change in how hard it pulls. Buuuut i have a new noise. Again, see new post plz.
Boost is a big deal. +1 on what Way had to say. The hydraulic damper on the stock setup keeps constant tension on the belt. Part of your noise could have been belt slap. Your new post/video/audio hasn't shown up.
My bad. With so many people home from work, the forum is running a bit slow. That new audio does not sound like a crankshaft damper to me and the fact that you have achieved 15lbs. of boost should mean it's not slipping. As much as I hate to say it, that sounds more like a crank bearing going/gone bad.
What should I look into to check into the bearings that doesn't require extensive work ? Or is that not possible ? Should i look for metal shavings in my oil or anything ?? Now I'm scared .
