R50/53 OBDII app
Old Mar 3, 2020 | 08:14 AM
mayagrafix's Avatar
mayagrafix
OBDII app
Does everyone use Torque as their OBDII app or is there a better app specific for Mini?
Old Mar 4, 2020 | 01:39 PM
gumbedamit's Avatar
gumbedamit
You can use Torgue for basic codes, but there are specific Mini functions that Torgue can't read or reset. I use a Mini/BMW/RR specific scanner, (Schawben). Works well, and you can do lots of troubleshooting,(Testing Components) with it.
Old Mar 4, 2020 | 04:12 PM
tej98's Avatar
tej98
I just recently started using Torque and like it so far. The data logging feature is pretty cool!
I'm working on getting a ISTA and INPA setup for a more in-depth analysis.
Old Mar 4, 2020 | 04:22 PM
ssoliman's Avatar
ssoliman
See my post named “inpa”...should have all the details you’ll need. You’ll not regret it
Old Mar 20, 2020 | 10:33 AM
USNAE2's Avatar
USNAE2
Veteran: Navy
I use Torque and have been able to clear any code which has popped up. Usually the same code (P0171 System too Lean) every 3 to 6 months or so.
Old Mar 20, 2020 | 12:07 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I use car scanner . I found it to be more accurate with trouble codes than torque
Old Mar 20, 2020 | 02:11 PM
cooper48's Avatar
cooper48
Car Scanner Pro is a good OBDII code app. In addition to codes, it allows you to set up gauges like Boost, Acceleration, Fuel Used, Miles Traveled, etc. It also has a neat feature to measure speed over distance, i.e., 0-60mph readings.
Old Mar 20, 2020 | 04:52 PM
dedave's Avatar
dedave
Which one can clear srs codes? I contacted blue driver and they said no, their scanner can't.
Old Mar 20, 2020 | 08:06 PM
MiniManAdam
Community Builder
I think your gonna need something more than a dongle and an app to do that .
Old Mar 26, 2020 | 04:33 PM
David Baker's Avatar
David Baker
Autel makes the stand alone OBD2 scanners that can also clear SRS codes for MINIs. I installed an amp under the passenger seat of my MINI and when I was testing, I completely forgot about the fact that if you turn the ignition on with the seat out, it sets the light. The dealer wanted $150 to "hook it to their computer", the tool cost me just a little over $125. If you want more details, let me know and I'll look up the specific one I bought but they do work for MINIs and many other brands.
Old Mar 27, 2020 | 12:07 PM
Webhead68's Avatar
Webhead68
Which model did you get?
Old Mar 27, 2020 | 12:27 PM
David Baker
Autel Autolink AL619 Scan Tool with ABS/ SRS Airbag Warning Light OBD2 Scanner, Turn Off Check Engine Light Automotive Diagnostic Tool, Quick Test On The Engine System Scan Tool
Amazon Amazon
it appears the price has come down since I purchased mine.
Old Sep 7, 2024 | 03:46 PM
Mforce's Avatar
Mforce
Are we still talking about the same car? R50/R53?
So Autel Autolink AL619 clears the Airbag light?
I have mine Airbag light is ON --- mini cooper s 2004.
Old Sep 7, 2024 | 04:23 PM
David Baker
yes it does. There is a separate section you go into when the unit boots up but it can clear the ABS/SRS light as long as the condition that set the light has been corrected.
Old Sep 7, 2024 | 04:58 PM
Mforce's Avatar
Mforce
Got it thank you... let me order this AL619. This light is really annoying.
Work or not it's fine... I need another scanner anyway.
I am hearing about this ISTA app how hard is this to install\acquire,? I've seen threads that it needs special plugs and adapters.
Old Sep 8, 2024 | 07:06 AM
David Baker
when I had an R50 and R53, I used NCS Expert and NCS Dummy. Didn’t use ISTA so I can’t help there.
Old Sep 8, 2024 | 07:26 AM
Mforce's Avatar
Mforce
Can buy these NCS Expert \ Dummy somewhere legit?
Armytrix_Exhaust
Mar 8, 2022 06:39 AM
Armytrix_Exhaust
Jul 11, 2019 02:58 PM
TSur
Electrical
18
Oct 11, 2013 06:23 PM
welcha13
Aug 9, 2012 04:54 PM
