R50/53 Pcv valve broke bolt
Old Mar 2, 2020 | 08:02 AM
theDonVon's Avatar
theDonVon
My pcv valve main bolt to take it off I was gonna replace it. What should i do now i reallly dont wanna buy a new valve cover. Is there anyway I can clean it while it's still in the car
Old Mar 4, 2020 | 05:43 PM
Racingguy04's Avatar
Racingguy04
I'll confess I'm a little confused what happened here, but I suppose you could pull the hose off the pcv valve and squirt some carb cleaner in it. I'd probably do it when you change the oil so you don't have carb cleaner in with your oil.
A better solution would be to clamp some vice grips on the broken bolt and try to get that bolt out so that you can clean the PCV properly, and have a way to hold it in.
Old Mar 5, 2020 | 12:40 PM
Do you have a picture?
Old Mar 7, 2020 | 03:05 PM
theDonVon's Avatar
theDonVon
The 10 m bolt is broken flush into the valve cover and since its plastic I dont think I should drill it out. I really need help with this
Old Mar 7, 2020 | 06:35 PM
Racingguy04
I'm fairly certain that the crank case has a metal insert that serves as the thread for that bolt, though it's been 4 or 5 years since I've seen one. I think you ought to be able to drill the bolt out. Start small, make sure it's centered, and go slow.
If you can't get vice grips on it, I think the only option other than replacing the valve cover is drilling out the bolt.
speedman
Jul 9, 2019 07:38 AM
2011BlackR56
Mar 5, 2017 05:41 AM
minnella
Feb 4, 2016 02:56 PM
pizmo pete
Mar 17, 2010 07:01 PM
nigelthecooper
Aug 6, 2009 07:12 PM
