R50/53 Window from when opening door?
Old Mar 1, 2020 | 11:28 AM
alconk's Avatar
alconk
Is there a way to adjust how much the window drops when you open the door? My Windows barely drop, I can push the glass down a 1/4” and when I shut the down it seals back up. On the window regulator there is a plastic adjustment screw on the cable but don’t know what that would do.
Old Mar 1, 2020 | 04:21 PM
MVPeters's Avatar
MVPeters
That's about how it should work - it's to stop the glass, which has no frame, from slamming against the rubber seal when you close the door.
There is a reset for it which might make a slight difference:
Close the door.
Press the window switch down & hold it for 5 seconds - then press the window switch up & hold it for 5 seconds.
See if it's any different. I think it's OK as it is.
Old Mar 2, 2020 | 03:41 PM
alconk's Avatar
alconk
Close the door.
Thanks I understand that but what I was saying the glass barely cracks when it’s opened like something is worn. It should drop a little more than what it does. Then when the door is open I can literally push on the glass downward about a 1/4” which is what I think it should drop.
joedotmac
Jul 23, 2022 01:02 AM
zwazoo
May 6, 2014 08:24 AM
julesagogo
Dec 15, 2010 07:23 PM
jujucooper
Oct 22, 2010 11:46 AM
