JCW GarageInterested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
I need some help/advice for figuring out whether or not this is a R52 Cooper S with the JCW package or a factory R52 JCW. The thing that is throwing me off right now is the Cooper S badge on the right side of the rear of the vehicle; however, it also has JCW badges on the front and rear. How can I tell definitively that this vehicle is a factory JCW and not a Cooper S with the JCW package? It is listed as a "2008 Mini convertible JCW Edition". Any and all input is greatly appreciated.
M
Reason: wrong model number
You can run the VIN with an online decoder to see if it shows code 3AL for JCW kit. If factory, the car should also have the JCW brakes and a limited slip differential, unless it was different outside of the US. If not factory, the JCW kit could still have been added later. The hardest thing to see is if a JCW head is on it without removing the head, or at least the header to see the exhaust ports.
It does have the full aero kit (not a JCW item) which is very rare since the pieces are no longer available.
Reason: Added further JCW info
Run it thru a VIN decoder (to see if its a factory JCW). It could be a dealer installed kit. Hopefully it has a certificate that matches number on
airbox and valve cover JCW badges. It should have those, red JCW brake calipers on the front, and a SS angled tip (versus rounded pipe) exhaust
All (including factory JCW's) are badged as S models
Now is it a real JCW? Have to run the vin, and then inspect the parts such as the brakes, supercharger pulley, injectors, airbox, head, and engine badge.
Hi everyone, thank you for the input! I contacted the seller for the VIN and here it is: WMWRH33578TU81087
The VIN checker on NAM is showing it as a Cooper S; however, it's still possible that it has the dealer upgrade kit? I will ask the seller for any paperwork that they have regarding the specs of the car. In the meantime, does anyone have any more insight based on the VIN?
Thanks for the update! Would you be able to please send me a screenshot of your results? She is asking $12k CAD ($8944 USD) and it has 125,000km (77k miles) on it. I haven't seen the car yet. Wanted to confirm that it had the JCW kit. From the pictures, it seems to be in great condition.
