R56S Won't start after pulling intake off of turbo
Old Feb 26, 2020 | 01:18 PM
jayyredd's Avatar
jayyredd
Hey guys, I recently just did a complete engine overhaul (new pistons, head gasket, timing chain set), the car started up brilliantly well (first crank) when it was all put back together.
It was running fine until I started to do some tinkering under the hood while it was running. I removed the turbo inlet pipe off of the turbo while it was running, the car began sputtering, then just died out (for obvious reasons). It will crank over but not start now.
Scanned with ISTA-D, no codes thrown. Replaced crank and cam sensors; no dice. Cleared all faults in ISTA-D (if any), still no start.
The car will ignite once, but not start. (spark once, then nothing)
Going to re-check my timing tonight, but is there anything that would prohibit a start after doing what I did?
Thanks!
Old Feb 28, 2020 | 09:14 PM
jayyredd's Avatar
jayyredd
Edit: timing slipped on the intake cam. We're all set now
cyberlunacy
Mar 21, 2019 04:29 PM
R56SinMD
May 25, 2016 11:32 AM
actasci
Apr 29, 2016 12:45 PM
switch
Feb 23, 2015 09:29 AM
McLaren-Saleen
Jul 20, 2012 04:40 PM
