R50/53 Coolant Overfilled
Old Feb 25, 2020 | 11:51 PM
CooperSPT's Avatar
CooperSPT
Coolant Overfilled
Hi, if I’ve overfilled the Coolant, where does it discharge to?
Old Feb 26, 2020 | 05:37 AM
Minibeagle's Avatar
Minibeagle
Do you mean you've put too much coolant in the overflow tank? If so, just remove the excess with a turkey baster until you reach the MAX level line.
Old Feb 26, 2020 | 08:45 AM
CooperSPT's Avatar
CooperSPT
Hi yes, that's exactly what I mean.
But if I have overfilled and driven the car. Where will the excess water come out? From the cap?
Only I have traces of water at the back of the engine after filling and driving??
Old Feb 26, 2020 | 08:59 AM
gumbedamit's Avatar
gumbedamit
It will create enough pressure to vent through your cap, or it will make the seam of your plastic recovery tank fail. If there are any weaker components , ie, hoses or seals, it will leak through there.
Old Feb 26, 2020 | 02:37 PM
CooperSPT's Avatar
CooperSPT
Thanks for reply.
looks like I need to check the level and probably remove some coolant from the tank.
thanks again.
surfin'02
Sep 17, 2020 09:06 AM
imbz
Mar 12, 2009 09:01 PM
TheBigNewt
May 14, 2008 07:51 AM
flav
Nov 6, 2007 01:08 PM
flav
Oct 13, 2007 11:43 AM
