R56 P1497 & P0507 fault codes, idle surge
Old Feb 23, 2020 | 12:02 PM
Grusvag's Avatar
Grusvag
After replacing the water pipe, from water pump to thermostat, and having much of the intake pipes off, the car has been having an erratic low idle. Dips to 400 or 500 then surges up above 1,000 then drops back down to normal. Only notice it at idle and have checked the hoses, clamps, even did a smoke test. Nothing obvious and it seems like it could be a myriad of things but thought I'd ask here.
-valve cover?
-pcv valve?
-throttle position sensor?
Old Feb 24, 2020 | 09:09 AM
MiniToBe's Avatar
MiniToBe
all of the above PLUS the PCV pipe that routes thought the intake. there is also the gas tank purge valve.
t0mthebomb97
Mar 14, 2024 03:17 PM
HoosierCooper
Sep 3, 2021 11:34 PM
cagersguy55
Dec 21, 2018 09:27 PM
toiletduck
Jan 18, 2017 08:56 AM
midacl
Jan 15, 2014 04:55 PM
